rear seat lift!!
Old Jul 14, 2009 | 08:51 PM
trojanman22's Avatar
rear seat lift!!
WHERE DO I GET ONE!?!? i need like a 4" rear seat lift. i have an 07 crew cab. im puttin in 2 jlw1 12's. only seat lift i could find is from lmi welding but they only have a 2.5" lift....
Old Jul 14, 2009 | 08:53 PM
05RedFX4's Avatar
I think the LMI lift is the only one out there.
Old Jul 14, 2009 | 08:54 PM
IDNC76's Avatar
Old Jul 14, 2009 | 08:56 PM
bigdog87's Avatar
IT is.. You aren't getting a 4" lift, unless you make it yourself. Then your rear seat would be worthless. Get different subs.. Or a blowthrough or some sort of custom box.
Old Jul 14, 2009 | 09:26 PM
yetti96's Avatar
4" custom seat lift sounds like it would be dangerous. If you want huge subs and huge sound, you need to either rebuild a seat to be a padded box or make a custom center console, or loose a seat. Options are out there, just not necessarily what you are thinking. Moving the seat 4" closer to the ceiling sounds like almost useless seating. I like where this is going though.
Old Jul 14, 2009 | 10:32 PM
marcolarco52's Avatar
you want to add a 4" seat lift to fit 2 subs that have a mounting depth of 5-1/8"....you can fit those subs without a seat lift...hell with a 2.5" seat lift you can fit 2 12w6's i believe or atleast w3's for sure lol
Old Jul 14, 2009 | 11:25 PM
alexarizpe's Avatar
i have 2 10" memphis m3's in my supercab with no seat lift and the mounting depth is about 6" and they fit fine. i think a 2.5" seat lift would be good. post some pics if you do buy it.
Old Jul 14, 2009 | 11:30 PM
dilloncawthon's Avatar
dang 4in. lift, hope you cut holes in your roof. a 2.5 will prolly suit you fine, or better yet make a box with a coushin on top of it for like two ported 12's
Old Jul 15, 2009 | 12:02 PM
Indo's Avatar
I went with LMI Welding and their 2.5" seat lift. My 10W3v3's fit just fine.
Old Jul 15, 2009 | 02:43 PM
sldghmr's Avatar
Originally Posted by dilloncawthon
dang 4in. lift, hope you cut holes in your roof....
....with Lexan bubbles!! I think that would be cool!!
Old Jul 15, 2009 | 03:35 PM
weazel's Avatar
Registered User
no need for 4"s if i can fit 12W6 under there then you should be able to get w1's which is a waste if you use that with the lift..
Old Aug 29, 2009 | 07:24 PM
yeah i ordered the LMI welding lift and im installing it as we speak. i just wanted as much space as possible but im not gonna have any trouble at all fittin em under there.
