Need VIN from Snow Plow Prep Package Owner!
Old Jul 13, 2009 | 11:57 PM
AAK625's Avatar
Exclamation Need VIN from Snow Plow Prep Package Owner!
Hey all, hope you are doing well. In order to locate the part number for the heavier duty springs, the Ford Parts Guy says I need to get a VIN from someone who has the Snow Plow Prep Package on their truck.
Please post it here or PM me!
Thanks in advance,
Anthony
Old Jul 14, 2009 | 06:05 AM
svt2205's Avatar
Check your PM.
Please post the spring part number when you get them.
Old Jul 14, 2009 | 07:57 AM
yetti96's Avatar
I wonder what the difference in spring rate is?
Old Jul 14, 2009 | 09:41 AM
AAK625's Avatar
Thanks guys!
Old Jul 14, 2009 | 08:37 PM
AAK625's Avatar
Originally Posted by svt2205
Check your PM.
Compliments of Domenic at Tasca:
Front Springs 8L3Z5310Z $55.47 each
Rear Springs 4L3Z5560SC $196.79 each
Old Jul 14, 2009 | 08:58 PM
GreenBuck50's Avatar
I didn't know they offered snow plow prep packages on 150s.
Old Jul 16, 2009 | 09:37 AM
AAK625's Avatar
From these folks:
http://trailer-bodybuilders.com/snow...idelines_0908/
Ford Trucks
Minimum recommended equipment for the F-150: regular cab 4×4, 144.5" wheelbase, 8' pickup box; or SuperCab 4×4, 163" wheelbase, 8' pickup box.
Snowplow prep package (option code 63A) includes FGAWR upgrade to 4300 lb (4300 lb spring rating).
Heavy Duty Payload package (option code 627) includes: 8200-lb GVWR; 4050-lb FGAWR (4050-lb spring rating); 4800-lb RGAWR (4900-lb spring rating); rear axle capacity upgrade to 5300 lb and 10.5" diameter ring gear 4.10 ratio, limited-slip not included but available; 17"×7.5" J 7-lug steel wheels; LT245/70R×17D BSW all-season tires (5); 5.4L, 3-valve V8 engine, 4R75E automatic transmission; Super Engine Cooling (1.42" core thickness); auxiliary transmission air cooler, oil-to-water increased to 9-channel/18-plate; battery upgrade to 72 amp-hr/650 CCA; fuel tank (35.7-gallon capacity).
Thanks for your help guys. The freight company weighed in the bumper at 175lb. I thought it'd be much, much, heavier. I probably won't need the beefier springs.
Old Jul 16, 2009 | 10:52 PM
XPerties's Avatar
I work for a major plow install company and we have guys come in all the time who want plow packages on 150's and we turn them away unless they want poly plows. No a good idea to put any steel plow package on a 150 regardless on any upgrades done.
Old Aug 6, 2009 | 02:20 PM
Duc23's Avatar
Will the snow plow prep springs raise the front end on the 2009 F150's?
Has anyone installed these springs on your non-prepped 150?
Old Aug 6, 2009 | 02:36 PM
05RedFX4's Avatar
No, all 150 springs are the same height, but they have different spring rates.
