Who has installed the Champion plugs in their 5.4?
I installed the one piece Champions about 3000 miles ago and have no complaints. My truck runs better then it did with the Motorcrafts, and my MPG has improved as well. I immediately noticed a much smoother idle (new plugs I know
), and smoother acceleration.
The acid test will be time. If it's still running as good at 20 or 30K then these plugs will be the only ones I use.
), and smoother acceleration.The acid test will be time. If it's still running as good at 20 or 30K then these plugs will be the only ones I use.
i went with the brisk plugs had one f up on me the porecilin seperated from the treads it was a variable gap plug
got 8 new ones now for about 1000 miles , i think i sleep better at night knowing they wont break
got 8 new ones now for about 1000 miles , i think i sleep better at night knowing they wont breakTrending Topics
Ford doesn't make the plugs. Noone wants to pay for the design and tooling. Ford fixed the head design in 2008, so there is no incentive for them.
This I did not know. So what about us guys with pre-08 trucks? Even if we get the original plugs out ok and replace them with Motorcraft, we could have the issues next go round right?
The theory is as long as you put the anti-seize on the sleeve portion then the problem won't return.
