Help on unbolting motor mounts and raising motor
Old Jul 1, 2009 | 03:12 PM
don40vette's Avatar
Does anyone have some pics showing which bolts to lossen on motor mounts and where to place jack to raise motor? Thanks
Old Jul 1, 2009 | 03:21 PM
Tylus's Avatar
you're not serious are you?
Recommend you don't attempt this repair since you don't seem to know what you are doing
FYI, get a piece of plywood. Use this between the oil pan and the jack. It will spread the load equally and prevent you from punching a hole into the pan. Depending on the clearance of the subframe, you might actually have to use 2 seperate jacks. 1 infront of the subframe, and 1 behind the subframe. The piece of wood will run the area between them
Old Jul 1, 2009 | 03:49 PM
don40vette's Avatar
If I knew what I was doing I would not be asking. I'm capable of doing it cause I installed the Roush Intercooled Supercharger in my truck. There are two bolts and two nuts on the passenger side motor mount, not sure which should be loosened. I know you can place a board under the oil pan but I think there is a spot the jack can be placed without lifting from the oil pan. I'm not an expert but with some help I can sure get it done.
Old Jul 1, 2009 | 03:56 PM
IIRC we used a 6" 1/2 drive extension as a jack extension, and the loosened the bottom bolts out and lifted the mount and engine together, but we only needed to lift the passenger side a few inches to clear enough room to get the longtube header intalled.
i think we placed the extension right on the motor mount itself.
Old Jul 2, 2009 | 10:00 PM
Tbird69's Avatar
Just something to be aware of before you lift anything. Once you unbolt the mounts and jack up the engine, there's a very real possibility the holes won't line up when you let it back down. That will make your project alot harder then you planned on.
