07-08Expedition20s?
Old Jul 1, 2009 | 02:33 AM
tman07f150's Avatar
07-08Expedition20s?
Sorry, I am still a little new here, but I was just curious.. I figured I was right but I wanted to make 100% sure, I have an 07 F150 2wd stx rcsb, and found a set of 07-08 OEM 20inch Expedition Limited wheels, Im assuming they will fit straight onto my truck just how they do on the Expeditions right,.. Im expecting they will fit like stock and sit right underneath the truck, b/c thats what Im wanting.. I know they are the same bolt pattern.. correct. Sorry Im a little new to this just wanted to make sure before I purchased, How much do they run for, would $400 for a set in pretty good shape w/o tires.. be too much or can they be found cheaper? They are the 6 spoke design chrome OEMs on the Exp' Limiteds. thanks for any input..- Tyler
Old Jul 1, 2009 | 08:57 AM
05RedFX4's Avatar
Yep, they will fit. Those wheels are 20 x 8.5" and will allow a 305 wide tire with ease. Since FX2's and 2wd lariats, king ranches could be had with factory 20's they should fit your truck no problem. The factory tire on 20's is a 275-55-20 or a 32" tall 11" wide tire. As long as you don't go taller than 32" or wider than 12", you should be fine. A 32 x 12 would be a 305-50-20.
Here is mine with factory 20's and 275-55-20 after I lowered it to sit just like a 2wd with drop shackles, notice how much tire clearence I have, I have no rubbing issues at all. A stock height 2wd w/stock 20's will sit the same as mine. The expy 20's have the same backspace as the f-150 20's do so they will tuck under just the same.
Old Jul 1, 2009 | 11:00 AM
06yz250f's Avatar
we had a guy come into our shop the other day w/ those 20" expi wheels on his 06 screw, i personally didn't like it, i think the 20" f150 wheels would look better. i wish i had taken a photo of it i might be buying his front/rear bumper from him since their painted if they do ill get photos
Old Jul 1, 2009 | 01:08 PM
blackedoutV6's Avatar
i think they would look cool on a lowered truck
Old Jul 1, 2009 | 02:03 PM
Tylus's Avatar
yep, those tires will fit your truck 100%
I have them on my Expy in the sig below. Love them.
