04 Tow package
04 Tow package
How can you tell if a vehicle is equipped with a tow package or not? What should be present on a vehicle that has the tow package? I have an '04 Supercab 4x4 Lariat. If there is a tow package, can it be turned on and off? On my GMC Sierra, the tow package was able to engaged and disengaged by simply pushing a button. Just curious if the same on the F150. Is there something in the codes that can tell you?
Thanks, I have all the above on my '04. My former GMC had a hard shift pattern and disabled OD when tow package was engaged. Just seeing if same on 150.
I continue to learn from you folks.
Nah, the only thing to do is turn off the OD when towing. That's just a button press, though. Other than that, if your truck has the tow package, it's good to go.
