gauge needles move after truck is off
Old Jun 20, 2009 | 12:03 PM
randygh's Avatar
Hey guys’ trying to find out if this is a problem or just normal. Ok so if I turn key off gauge needles all drop down right like you would think but if I wait about 15 sec they drop a little more and then pop back to where they were at.
Truck is a 2006 F150 5.4
Any help would be great.
Old Jun 20, 2009 | 12:40 PM
way2qk4u2c's Avatar
Ive seen this on mine as well...
Kinda weird....
Old Jun 20, 2009 | 02:13 PM
Ftruck05's Avatar
Maybe the battery going. Do the guages ever "sweep", run all the way up and back down?
Old Jun 20, 2009 | 04:37 PM
top_sgt's Avatar
gremlins or trols????? (jk)
Old Jun 20, 2009 | 04:56 PM
NicksSmokestone's Avatar
Mine do the same thing on my 06 .
Old Jun 20, 2009 | 05:46 PM
farmboybrent's Avatar
Registered User
I know my battery is low. But when I start mine the needles set there and "wiggle" in the off position for about ten seconds then they go to the on/ normal spot. Does anyone else's do this?
Old Jun 20, 2009 | 06:13 PM
blackjack8900's Avatar
I have the same truck as you....mine does it as well.....Normal as far as I am concerned.
Old Jun 20, 2009 | 06:15 PM
That seems like it's not normal....They should pop up right when you start the truck, at least they do for me. If your battery is good enough to start the truck, that should not be the problem.
Old Jun 20, 2009 | 10:10 PM
fomoco466's Avatar
gauges
it's fine. nothing wrong, it's just like some motorcycles when you turn the key on the needles do a full sweep, like a self test, then they go to the normal spot....for those of you who change or alter your cluster remember this when you put the needles back in place...as this will aid in the proper allignment.
his question siad it happens with the truck is being turned off.... has nothing to do with the battery.
Old Jun 20, 2009 | 10:24 PM
Registered User
It only happens when the battery gets real low. Like when i've been bumpin my subs for a while and then it will barely start then the needles will wiggle then they will come on.
Old Jun 20, 2009 | 11:19 PM
It's supposed to recaliberate the gauges.
Old Jun 22, 2009 | 01:12 PM
randygh's Avatar
thanks for all the input guys.
i have never seen them sweep. i just was not sure if this was normal sense i got it used.
