Whats the best way to get off the ground???
Old Jun 7, 2009 | 07:37 PM
jro08's Avatar
I have a 07 reg cab and i want to be higher off the ground without spending a tone of money.im running 33's but would like to go to 35's so im jus looking for some ideas (pics)
thanks
here a pic of my truck
Old Jun 7, 2009 | 07:44 PM
Djacobs28056's Avatar
2.5" leveling kit and 1.5" Add a leaf kit. Around $250-350 installed yourself plus alignment
Bodylift. 3" around $350-500. installed yourself. Little more expensive but another 1" of lift.
Old Jun 7, 2009 | 07:51 PM
thirdgenbird's Avatar
4wd front struts, a 2-2.5in leveling kit, and 4wd rear blocks will give you the most for the money
Old Jun 7, 2009 | 08:00 PM
jro08's Avatar
withe the 3" body lift i will still need a leveling kit right?
thanks for the help guys
Old Jun 7, 2009 | 08:02 PM
jro08's Avatar
about how much of a lift will that give me?
thanks for help
Old Jun 7, 2009 | 08:07 PM
dlenkewich's Avatar
As it appears on the main page:
Whats the best way to get off...
by jro08
Old Jun 7, 2009 | 08:13 PM
jro08's Avatar
by jro08
lol whoops sry bout that but thanks for letting me no
Old Jun 7, 2009 | 08:14 PM
Tylus's Avatar
4x2 or 4x4?
if 4x2, you'll need the following to stuff 35" tires
4x4 front coil-overs
2.5" leveling kit (front)
3" Autosprings rear blocks
You need the 4x4 coilovers to get 1" of more clearance, and then the 2.5" for a total of 3.5" to 4" of hieght up front
You need the 3" rear block to make-up for the OEM 2" 4x4 block, and then 1" of extra space...alternatively, you could install a 3" AAL, but that can be costly
if 4x4, you'll need:
2" or 2.5" Leveling kit
It's your preference if you want exactly leveled, or a slight rake. 2.5" will likely leave you perfectly leveled, or slightly nose high.
Also, replace your OEM 2" rear block with a 3" AS block...a little more room out back never hurts
EDIT:
You can brand new 4x4 coil-overs for cheap from http://www.newtakeoffs.com
eBay is your friend. I recommend Autosprings.
2.5" Leveling kit for $69-89
3" rear block for $125 shipped
Old Jun 7, 2009 | 08:22 PM
jro08's Avatar
Tylus thanks but would the 3" AAL be better?
Old Jun 7, 2009 | 08:30 PM
Tylus's Avatar
depends on your needs
3" block is cheaper, and gets the job done safely. Will not affect your ride quality at all
3" AAL is more expensive, and is safe as well. It will add at least 500lbs to your load capacity...but it makes the ride stiffer, more harsh
I don't see the need for paying almost double the $$$ for more load capacity that I didn't need...and a lowered ride quality. Others see different.
What are your needs/desires for the truck?
Old Jun 7, 2009 | 08:39 PM
Here's the only pic I have from the side. 3" level kit and Fat Bobs AAL. I actually didnt notice a ride difference and I installed them myself. $105 for the AAL and 3" in the rear (Probably settle to 2". I havent measured since install)
Old Jun 7, 2009 | 08:45 PM
jro08's Avatar
well with this truck im really jus going for looks and really jus a lil play in the mud.
Old Jun 7, 2009 | 08:48 PM
jro08's Avatar
ya it looks great was it difficult to install?
Old Jun 7, 2009 | 09:01 PM
shocker11's Avatar
I've been through this for a while now
1" rear block + 2.5" A/S spacer
or
1" rear block + 2.5" A/S spacer + 3" body
or you would do like me lol
2.5" rear block + 4" A/S spacer + 3" body = 5-6" lift overall
you're going to want the front about 1.5" higher than the rear pm if you need any help i've been though this ring around for a while!
Old Jun 7, 2009 | 09:07 PM
Not really! Only get a buddy to help you. Jack, Jack stands. c clamps are vital. I think I have 32s I'm going bigger when I wear these out.
