30k service quote - $480????????
Old Jun 2, 2009 | 10:58 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Ford doesn't want to charge you that much, it's these economic times that's causing it.
I took my old car to my mechanic because it was running rough.
When I went to pick it up he said, "Well, I fiddled with the carborator and seemed to have it running fine. Then I got this bill from my daughter's orthodontist and I had to pull the engine."
Old Jun 2, 2009 | 11:27 PM
FORDMAN0781's Avatar
Originally Posted by Desert Racer
Injector cleaner is just a bottle of crap they put in the tank that cleans your injectors nothing more nothing less. god i love having my brother work at a ford stealership. save a good amount on maintance cost and get to work on the truck as well. Also i did the collant change easy as cake. their is a lil plastic nylon bolt on the bottom of your radiator. loosen the coolant cap and let it all drain out than make sure you do not over tighten the little bolt to break it. and refill it and done. coolant is what keeps your motor cool no need to skimp on it.
A fuel system cleaner involves a direct feed of it. I had a misfire on my Grand Prix, did the tune-up (cause it needed it) and it still ran like crap. Clogged injector was causing my miss. A can of fuel injector cleaner right in the fuel line cleared the problem right up. A bottle in the tank is used in conjunction with the service under the hood.
Old Jun 2, 2009 | 11:31 PM
BrainDonor's Avatar
Old Jun 3, 2009 | 08:06 PM
RebelOne's Avatar
That's why I do everything myself. The dealerships are soo expensive. All of that maint. work is so easy, why no to do it yourself?
Old Jun 3, 2009 | 10:38 PM
mxracer49's Avatar
I was calling them about an extended warranty issue. My trucks at 28k so I decided to see how much a 30k service would be. Since I'm going to have it there shortly to get the rotors turned under warranty I figured why not do it all at once. No, they won't be getting my $480. They can turn my rotors for free and probably flush the transmission but that will be it.
Old Jun 3, 2009 | 10:49 PM
GTRider245's Avatar
Hopefully they will just drain and replace the fluid without flushing anything!
Old Jun 4, 2009 | 03:11 AM
memLT-1's Avatar
Originally Posted by Hawkz28
I did my 30k service for $50.
All you need is oil change, tire rotation, fuel filter, check fluids, air filter, injector cleaner.
And remind me why the dealers are trying to sell you guys a coolant flush when these trucks have 100k miles coolant, and why they are doing a tranny flush when FORD advises 150k mile for that as well???? If your towing a 6000lb trailer all day or "harsh" conditions there is a seperate maintenance schedule for that, but I doubt most of you need to follow the aggressive schedule.
Looks like Ford dealers like making the $$$. Look at the maintenence requirements from ford, it says 100k miles for coolant and 150k for tranny fluid flush. Also, the recomendded oil change interval from FORD is 5k miles, not 3k most dealers try and push on you.................
If it was up to the dealers they would have you come in every 1k miles for an oil change, every 5k for a tire rotation, and every 20k for a tranny and coolant flush
I agree my manual says 100k on coolant and trans fluid. As far as injector cleaner just use a bottle of Techron every oil change which for me is 5k.
Old Jun 4, 2009 | 03:44 AM
GreenBuck50's Avatar
I watched a service advisor tell someone it was $650. After that the customer asked why. The service advisor responded that it was business.
Old Jun 4, 2009 | 06:34 AM
STXbucko's Avatar
Please ask your brother at the dealership if that is how they (Ford) do coolant flushes. I just paid $89.00 at my local radiator shop. They connected a flushing machine to the upper hose, drained the radiator (as you pointed out), and then they ran the engine while connected to the machine to DRAIN THE BLOCK. Just dropping the coolant mixture from the radiator IS NOT A FLUSH!!! You are only draining the radiator if you mearly remove the plastic plug from it.
Flushing the transmission is the same way. It requires a flushing device that removes the ENTIRE transmission fluid. Most folks think that just removing the automatic transmission pan and draining it with a filter change is all that is needed. Not true at all. The torque converter holds about 3 or 4 quarts, plus your transmission cooler (if equipped) and/or the transmission cooler (small) that's built into the radiator. It makes no sense to drain and fill only 4 quarts (about what the transmission pan holds) and delute it with remaining dirty fluid, or coolant if we are talking about just draining the radiator.
If the dealerships are doing just a pan drop (auto transmission) or radiator drain (coolant) and calling that a flush, then indeed it is a rip off. I doubt they are doing that though.
A true coolant flush is about $90.00 to $110.00. Shop araound; most shops offer specials about this time of year. A true transmission flush is around $100.00 to $120.00. These prices are what I have seen in the Dallas Texas area.
Again, make sure they are flushes, dot just a pan drop or radiator drain. Those are not worth doing if you want to get all of the old liquids out.
As to injector cleaning, if you use a good brand of gas such as Shell, Mobil, or Exxon, your injectors will remain clean. They provide cleaners in their fuel that keep the injectors clean, plus prevent the carbon buildup on the piston tops and inner valve seats.
The $480.00 they quoted you is a fair price, IF they are doing true flushes, and not just a pan drop or radiator drain.
You wouldn't drain your oil and leave the old oil filter installed would you?
Old Jun 4, 2009 | 06:47 AM
jims94vmx's Avatar
also what is your time worth. i just went to a local dealer for an oil change and tire rotation for 40 bucks. last time i did it myself i had a little mess when pulling the oil filter, plus having to take it (dirty oil) somewhere to dispose of......again, how much time screwing around did i do??? 40 bucks is well worth the investment. just make sure you know what you are paying for and trust your dealer. my dealer will diagnose a problem and not charge me knowing if i need him i will be back. they are not all bad, but they do have to make a living....you just don't want them to retire on your dime only!! LOL
Old Jun 4, 2009 | 07:36 AM
GTRider245's Avatar
Hopefully it wouldn't matter, if you know the maint. schedule for these trucks, you will know they dont need flushes anyway at this mileage!
And the filter argument doesn't apply to the transmission.
