Camburg CRS Coil over on my screw!
Old Jun 1, 2009 | 03:58 AM
snotruck's Avatar
So it finally came in and I just got it installed. I set it to about 2.75 and it looks good to me. Slightly higher in the front but it gives it a little prerunner look.
Anyone think having it set that high will damage the cv axle or the uni-ball?
Also, I put on a nice magnaflow exhaust on it. Sounds great!
Old Jun 1, 2009 | 11:48 AM
fx4 for life 79's Avatar
take a picture of your angles so we can see but you should be ok just keep a look out if you use 4x4
Old Jun 3, 2009 | 06:57 PM
snotruck's Avatar
so i wasnt able to take pictures this weekend since i had to leave for work for 5 days
so i found some pics on the forums here that look EXACTLY like the angles I have. The dealership said to loosen and then re-tighten all the bushings and boots and it should be fine for 2.75 on the coilover.
also you think i can get a bfg all terrain 315 70 17 in there without any rubbing?
Old Jun 3, 2009 | 10:00 PM
bjp207's Avatar
those angles dont look bad, my 2.5'' AS gave me about 3'' of lift so 2.75 isnt that much
