Can see 3rd brake light through ceiling liner. 04 FX4 SCREW
Old Jun 1, 2009 | 01:12 AM
AAK625's Avatar
Arrow Can see 3rd brake light through ceiling liner. 04 FX4 SCREW
Hey guys, hope you're doing well. I happened to turn around today in the driver's seat and noticed a red spot of light coming through the headliner. Now, it's too faint for the camera to pick up, so I grabbed the closest object to point to it. If it matters, it's directly to the right of the night stick.
Any ideas?
Thanks for your time,
Anthony
Old Jun 1, 2009 | 01:18 AM
Easy -- Slip a piece of cardboard behind it.
Old Jun 1, 2009 | 01:22 AM
jjntj2003's Avatar
when i tinted mine it shined through also went back to factory no more light. if it's not tinted maybe a small piece of dynomat would be better than cardboard.
Old Jun 1, 2009 | 01:27 AM
Rhyde32's Avatar
yea i see it to. you can easily unscrew the brake light from the back and put something under it. I haven't done it yet, but it doesn't bother me too much.
Old Jun 1, 2009 | 01:38 AM
AAK625's Avatar
So, it doesn't mean there's a big hole there that will begin taking on water?
Old Jun 1, 2009 | 11:10 AM
Quintin's Avatar
There's a foam seal on the third brake light to prevent water from getting in the cab. Some '04s had problems with water leaks from the third brake light. I peeled the cheesy factory seal off the third brake light and put some thicker foam tape with a light coat of clear RTV sealer on mine.
Old Jun 1, 2009 | 12:38 PM
AAK625's Avatar
I ordered a Recon 3rd brake light not too long ago. Haven't had a chance to install it yet. I'll be sure to take these precautions. Thanks guys!
Old Jun 1, 2009 | 01:06 PM
BayouSupercrew's Avatar
I noticed that too, apparently ford put some holes in the bottom of the light, well to stop the light I just cut pieces of black electrical tape and covered the holes. End of issue. Works fine for me, YMMV.
Old Jun 1, 2009 | 01:09 PM
AAK625's Avatar
It's not so much that I was worried about a faint spot of light, I just don't need water flowing in there.
