Front Coil Replacement Question
Old May 30, 2009 | 03:35 AM
Drew5's Avatar
I have a Bilstein Leveling kit on its way for my 2004 FX4 and I want to replace the front coils and remove my spacer leveling kit at the same time I am having the Bilsteins put in. I am having trouble determining the right coils to get. OEM is fine with me. Any help determining what the right coil is would be appreciated. I found some online but they state 2004-2005 2wd/4wd front coil springs. I would not think my FX4 has the same front coils as a 2wd...Maybe I am incorrect.
Old May 30, 2009 | 08:51 AM
05RedFX4's Avatar
2wd and 4x4 front springs are the same. The shocks are different.
Old May 30, 2009 | 10:24 AM
Windsor's Avatar
The spring will physically fit, but spring diameter, coil count and the length of the coil determine the spring rate which can account for a different ride height. It's unlikely Ford uses the same spring for a regular cab 4x2 with a 4.2 vs. a super crew 4x4 with a 5.4.
Old May 30, 2009 | 10:46 AM
Dstang's Avatar
Go to your delear and give them your VIN and they can give you the right spring...
Old May 30, 2009 | 11:57 AM
Drew5's Avatar
Thanks. I am going to give the dealer a call today.
Old May 30, 2009 | 03:40 PM
Drew5's Avatar
Found out I have a code U spring and can get them from the Ford Megastore in Seattle for $45 a piece. Cheapest I could find online.
