Has anyone painted upper bumper
Old May 25, 2009 | 03:11 AM
jro08's Avatar
hey guys i have an xl model and i was wonderin if its ok to paint the upper bummer or best way to take care of my problem ??If so can i see pics
thanks
Old May 25, 2009 | 03:31 AM
GreenBuck50's Avatar
I bought a used upper bumper off of eBay, painted it, and swapped it out on my XL.
Old May 25, 2009 | 03:35 AM
jro08's Avatar
how much did it run u?? and what about the trim around the grill did u do the same with that?
thanks for the help
Old May 25, 2009 | 05:08 AM
thanks for the help
It was about $130 shipped for the bumper cover. It had slight damage but looks new with the hood down (a 2 inch rip is covered up by the hood being down. To have it painted, and installed along with the painting of the grill surround that I had painted it was $600 installed. I had it professionally painted and installed at a body shop. They had to remove everything on the front including the fog lights. I want to keep the truck for a very long time so wanted it done right. I bought the grill surround on eBay also for $50 shipped. It was painted silver, I had it repainted along with the bumper cover. So all in all including the Roush grills I have $950 into the front end of my truck, but it will last for years.
Old May 25, 2009 | 10:06 AM
bjp207's Avatar
With some sanding, you can make the thing paintable, it just takes a little time, it will be cheaper
Old May 25, 2009 | 10:17 AM
animated_zombie's Avatar
i have the same problem. i've talked to a few body shops about painting it. all of them said that while you could paint it, you'll still have the texture. i know i'm planing on replacing it before i PTM. if you paint the textured piece, i'll be curious to see how it turns out!
good luck!
Old May 25, 2009 | 10:19 AM
bjp207's Avatar
Sand the texture out, its the same as the mirrors, people smooth them out on a regular basis
Old May 25, 2009 | 01:10 PM
powerz69's Avatar
I had a bunch of rock chips that stood out and large scuff. Mine is white. I sanded them out resprayed with a color match spray can. I did 3-4 coats fine sanding in between coats. The white base was smooth just needed a clear coat but ran out of time. Now I have to start all over as this was 6 months or so ago. This is white very easy, depends on the color you need.
Old May 25, 2009 | 02:35 PM
jro08's Avatar
ya your front end look nice good work thanks for help
Old May 25, 2009 | 02:37 PM
jro08's Avatar
have u done it? if so have any pics i can see?
