Thoughts on Dynamat for doorskins etc..
Old May 22, 2009 | 11:02 PM
FX4 Matt's Avatar
Registered User
Originally Posted by GTRider245
How about you save your money and go to Lowes/Home Depot, head to the roofing section and pick up some Peel N' Seal. Same stuff as Dynamat, but WAY cheaper. Works just as well.
True but it stinks up your truck I used that stuff in my old ranger.
Old May 23, 2009 | 04:47 AM
Black Truck 10's Avatar
I used Raammat and I love it. Its not as expensive as dynamat, butyl based, and thicker. I put 2 layers in my doors and I also sealed the access holes to the doors. I also put it along the back wall and floor and I plugged up 1 rear vent hole. I would for sure do this again, it didnt make this amazing difference, like I can still very easily hear the drone from my magnaflow exhaust. It did help none the less. I used to listen to my radio at 20, I now listen to it at 14 with the same results so some would claim this is a 6db increase. 3db is when most people can tell a slight difference so take what you can from that.
