Power Tailgate Lock
Power Tailgate Lock
Just bought and am trying to install the Pace Edwards power tailgate lock. The instructions call to tap into 2 wires in the passenger side fuse box: Pink w/ Black Stripe and Red w/ Orange Stripe. The wiring harness in there has about 40 wires. I found the pink w/ black stripe, but the red w/ orange is not there. I see no red w/ orange going into the fuse box either.
The instructions for this are somewhat vague and cover a wide range of Ford models and Years. Check it out here: http://www.pace-edwards.com/pdf/pglk370.pdf
Am I missing something with this red wire w/ orange stripe? There is a red w/ yellow stripe in the harness. Anyone installed one of these? Any help appreciated. Btw, 2004 screw. Thanks.
I recently bought a Pop 'n Lock version. According to their instructions...
http://popandlock.net/index2.php?opt...d=25&Itemid=39
Hope this helps.
Originally Posted by pop n lock
4. Ford Ranger and Ford F-Series trucks and all trucks with keyless entry
Carefully remove the passenger’s side kick panel and find the wire harness with the pink w/red wire and the pink w/black wire.
All other Ford Ranger and Ford F-Series Trucks
Carefully remove the passenger’s side kick panel and find the wire harness with the pink w/orange wire and the pink w/black wire.
NOTE: All 4 door models (Supercab, Super Crew, Sport Trac) have the connection point in the driver’s side rear door step plate and B-pillar. The wire colors remain the same.
Hope this helps.
Hope this helps.
Hope this helps.
Thanks for that link. Your instructions call for the pink w/ black and pink w/ red. Mine call for the pink w/ black and red w/ orange. Also your instructions say all 4 door models have connection point on driver's side rear door step plate. So I've got some stuff to try when I get off work!
I'll pull the driver's side sills this evening. Looked at passenger side front last night and didn't see it.
Yeah yours have instructionis for keyless entry, or without. Mine don't even specify, although it says it will work w/ keyless entry trucks. Yours don't mention the red w/ orange, which is the wire in question for me.
didn't have time to do it last night. i just wanted to see if i could locate those wires. I'll probably finish the install tonight.
That's cool that you could piece it together that way. I don't have enough knowledge to do that...had to buy the kit. It was around $80 shipped from amazon. Pics look good.
