*** Firestone Ride Rite Airbag B4-n-after pics ***
Old May 6, 2009 | 05:21 PM
  #31
rms8's Avatar
Originally Posted by 06 SANDSTONE
I have the same set ride rite bags . I had to do something different After i lifted it .
WOW, that looks really good!
Old May 6, 2009 | 05:39 PM
  #32
efuehrin's Avatar
Originally Posted by GTRider245
Good deal. Until now, I was honestly under the impression that the on board compressor was required when using air bags.
There is an in between option if you have some room.
You could instal a air tank and use that to air up your bags or whatever.
Just fill it with a shop compressor.
I've got a 10 gal under my bed and it lasts a long time. + if I get a flat or something I always have air.
click here for pics of my setup
Old May 6, 2009 | 08:22 PM
  #33
rms8's Avatar
It's funny you mention this. I have a 5 gallon tank I use for various things from time to time. I should just leave it filled in the bed of the truck!
Old May 6, 2009 | 09:11 PM
  #34
06 SANDSTONE's Avatar
Originally Posted by 6868vfco
I saw that in one of you other post pretty crafty looks factory too. Good idea using those tubes. How are they holding up the actually look more supported than the regular supports.
There holding up great . Its better that this option .IMO
Old May 6, 2009 | 09:14 PM
  #35
Heres where i installed my remote valve. I'll soon have it hooked up to my onboard air .
Old May 7, 2009 | 07:34 AM
  #36
GTRider245's Avatar
That's slick. Off hand, does anyone know the PSI it takes to fill these bags?
Old May 7, 2009 | 08:23 AM
  #37
05supercrew's Avatar
Truck looks great.
Old May 7, 2009 | 10:32 AM
  #38
efuehrin's Avatar
you can fill them up to 100 psi (MAX)
however I never go over 90. cause when u hit a bump the pressure jumps.
Old May 7, 2009 | 11:28 AM
  #39
GTRider245's Avatar
Very true. These bags have relief valves?
Old May 7, 2009 | 11:31 AM
  #40
efuehrin's Avatar
No. I've seen mine bump up to 120psi.
Old May 7, 2009 | 11:41 AM
  #41
GTRider245's Avatar
Yikes. I think I would leave that margin in the bags as well.
Old May 7, 2009 | 11:43 AM
  #42
efuehrin's Avatar
Yea, Now I keep the pressure only as high as I need it and drive slow through the field till I get to a road. Then I can bump up the pressure some more.
Old May 7, 2009 | 01:47 PM
  #43
camlocker's Avatar
Is the ride any different than without? I opted for the 3" blocks after my 1.5" AS install. My truck sits 1/2" higher in the rear now, but would still like to know if it affected the ride. Mine rides a tad bit stiffer, but it could be the E range tires.
BTW, truck looks great.
Old May 7, 2009 | 01:50 PM
  #44
efuehrin's Avatar
With the minimum 10psi in the bags I can't tell a difference.
Of course if I jack them up to 90 psi with no load it's a bit stiffer.
Old May 7, 2009 | 02:46 PM
  #45
can you take some more pics of the bag mounts both upper and lower? Efuehrin you too!!
looking good!
-Patrick
