07 turn signal heated mirrors into 08 fx4 only power
Old Apr 30, 2009 | 02:05 AM
froshy00's Avatar
Ok so i searched and i have figured out the heated mirror wont work unless i make it work either via the factory rout with the A/C control and a fues box ( at least thats what i gathered) or a relay i mock up but would the turn signal function and all the mirror adjustments work fine? just plug and play? i have a truck i can get them off of for free but i have to do it tomorrow and have my truck back together so i can go to work. lol
too add more.. i think the are power folding too.. hmmm
thanks JOSH
Old Apr 30, 2009 | 02:15 AM
ATOM's Avatar
i have an 07 and i tried do this when i got the truck and it was not plug and play in my truck. the power mirror worked but that was it, i just said to hell with it and sold the mirrors. it may be wired but you would need to add pins in the connector because i know they are not there.
Old Apr 30, 2009 | 02:31 AM
froshy00's Avatar
what year truck was the ones you were trying to put in from? apparently that makes a differance.. ??
Old Apr 30, 2009 | 02:48 AM
ATOM's Avatar
i bought new mirrors from tasca, ones for the 07, yea the years matter. 04-06 are the same and 07-08 are the same
Old Apr 30, 2009 | 03:03 AM
froshy00's Avatar
o alright thank you caint get much closer on year then that then.. lol
Old Apr 30, 2009 | 03:05 AM
ATOM's Avatar
it's a possible swap, but it will take some figuring out of wires. i think someone swapped in tow mirrors and changed out the fuseblock and a bunch of step.
if you want signals in the mirrors, you could always get a set of signal mirrors from muth, they are replacement glass that has the "<" or ">" in, like the chevy's has. also they have them in heat too, so it would be easy to get the heat signal one and wire them to a switch. alot easier IMO to make work.
Old Apr 30, 2009 | 03:14 AM
froshy00's Avatar
well i can always wire the stock heated ones to a switch which is proly what i would do. dont wanna buy a a/c controller
Old Apr 30, 2009 | 03:23 AM
ATOM's Avatar
yea that climate control module is gonna be hard to hook up unless you got the plug in for the back of it.
Old Apr 30, 2009 | 05:03 PM
froshy00's Avatar
ya not really worried about that, i`m more worried about the wiring from the mirror to the module and so forth. stuff that i would have to mess with the harness. i dont wanna hack up my truck i only wanna add mirrors. ahaha
