Accleration while braking.
Old Apr 21, 2009 | 12:06 PM
mkosu04's Avatar
Originally Posted by Bartak1
If it ever happens its second nature to hit the brakes...but just try to remember to just turn the key off...much more effective then slamming the brakes when the engine is in gear and running 5000 RPM. Remember you wont have power steering or power brakes though.
You will still have power brakes... the vacuum booster is designed to provide approximately 5 stops before the vacuum is depleted.
(unless you have a bad check valve... then it could bleed down quicker)
Old Apr 22, 2009 | 04:28 AM
WstCstStylz's Avatar
This exact thing happened to my buddy with an 04 superduty. Pretty sketchy. It ended up being a bad sensor to his gas pedal. He almost rear ended a cop one time at a light. It took him three trips to the dealer for them to figure it out.
