bad miss
Old Apr 11, 2009 | 09:04 PM
squeeku2's Avatar
bad miss
i have a 07 f150 supercab 4x4 with 5.4. runs fine but often when stopped such as at a traffic light or whatever, it misses really badly and sounds like that noise u have heard when a car runs backward after u cut it off. it just does it about 30 seconds and then it is fine. or u can just rev it up and its fine. anyone know what this is? someone told me it is water in my gas. it sounds really bad when it does it and the whole truck shakes. thanks
Old Apr 11, 2009 | 09:22 PM
risupercrewman's Avatar
Does it throw a code?
Old Apr 11, 2009 | 09:24 PM
squeeku2's Avatar
no code. thanks
Old Apr 11, 2009 | 09:26 PM
Dealer/Warranty time.....
Old Apr 11, 2009 | 09:27 PM
squeeku2's Avatar
wish i had a warranty. u dont think it could be bad gas/water in gas? i bought the truck used about 3 months ago, ran fine til bout a week ago.
Old Apr 11, 2009 | 09:29 PM
Fill it up with some quality Shell Gasoline & see what happends......
Old Apr 11, 2009 | 09:31 PM
squeeku2's Avatar
yea, i filled it up at shell today, i havent drove it much yet since. thanks
Hope that works....
Old Apr 11, 2009 | 10:48 PM
c1t1d1's Avatar
If you think you have water in gas or bad gas go to walmart and get some gas treatment. You can always check your injectors to see if one might be going bad. Free and easy trick is to take a long screw driver put the tip of it on top of injector and put your eat on the other end were handle is, the screw driver will let you hear the injectors , listen to all of them and see if they all sound the same. If one sounds different , might be bad .
Old Apr 12, 2009 | 08:47 AM
squeeku2's Avatar
thanks, i will try that
Old Apr 12, 2009 | 10:47 AM
Nicky Pass's Avatar
I had a slight miss at idle and when I'd step on it pretty good, it would almost back fire. It ended up being 3 plugs and coils and an injector.
Old Apr 25, 2009 | 10:11 PM
sugar-rush's Avatar
My 07 Screw 4x4 sometimes does this. Let me know what you find out.
Old Apr 29, 2009 | 08:48 PM
squeeku2's Avatar
still doing it, has to be water in gas. Does yours sound really bad with knocks and pings when it does it?
Old Apr 29, 2009 | 09:11 PM
06yz250f's Avatar
you do realize the 3 year/36k warranty transfers right? unless your over the 36k miles
Old May 6, 2009 | 05:18 PM
squeeku2's Avatar
45000 miles. Ok, i have noticed that it only does it while parking or moving forward and backward a couple times. also if you stop on a hill. never in the level at a stop light or whatever.
