Prodigy Controller
Old Mar 31, 2009 | 05:23 PM
fitz888's Avatar
Prodigy Controller
Im sure this has been covered but the search sucks.Got my new 7000 gvw landscape trailer and need brakes its 1800lbs empty.Ordered the prodigy with the ford adapter but where is the factory plug hideing under the dash?Also have the trailer package in the dash with the relay wheres this go? 08 tow package.Thanks
Old Mar 31, 2009 | 05:56 PM
kd4crs's Avatar
Relay will go in the fuse panel and the connector for the brake controller is up inside the dash close to the steering column. It is a grey plastic connector and it should be the opposite of the connector furnished in the towing accessories package.
Old Mar 31, 2009 | 10:16 PM
blackjack8900's Avatar
Yep relay will go in the passenger side fuse block.
Here is it pulled out(of course you don't need to pull it out) it is the relay that is missing between the two gray ones.
Here is it with it in (the one on the left)
The connected for the brake controller is up behind the OBD II port.
Here is the plug for the brake controller, plugged in
Hope this helps
