Either my truck is a POS or LS fails!
So I got stuck, AGAIN! This time in the mud! What gives? Does LS not work in reverse? Or is mine just a slap piece of ****? I've got to get new tires, and or a new truck that's FREAKING 4wd! I can't take this anymore!
If you were in reverse, we have to assume that you pulled into mud, stopped, and tried to back out. In mud you gotta keep the tires spinning and keep your speed up or you're screwed.
I'm just assuming so if that wasn't the case then I apologize.
No, it's cool I didn't stop. I was going forward with good pace, and just tires caked and slipped into a rut, and just wouldn't go.
How many miles on your truck? You sure the LS still works? The clutches might be worn out if you use the LS a lot.
Get some wider tire's with a more aggressive tread pattern. My truck does great offroad now. The 325's have great floatation in soft soil. It's still not as good as a 4wd truck but for 2wd it's awesome.
18,200. Should still work, I'm getting new tires sometime, not sure how what tires, I don't have much money got to see what my dad will give me.
mine has 18,400 on it and the clutches still work fine, i'm sure 35's on 20's in the summer don't help it any, but oh well
Nope but it sure looks good!
