Why am i not getting good MPG?
Old Mar 28, 2009 | 09:11 PM
Moltenice's Avatar
I got 19.6 MPG from Seattle to LA.....
But that was 55-60 MPH, with easy slow starts and cruise control locked the whole highway.
Old Mar 28, 2009 | 09:38 PM
th3godf4th3r's Avatar
Yes it is caliberated, I have it pretty close to being correct. The wheels and tires are heavier but not that much more than the stock 20's
Oh well it just seems I could be getting better
Old Mar 28, 2009 | 11:13 PM
Old Dogg™'s Avatar
Just a guess but I would bet you lost some low end compression performance thru your exhaust mods. Performance wise straight thru's usually gain hp at WOT but loose low end performance. Your truck may be less efficient climbing hills also because of this?
Your exhaust and cai may be working against you and those hills also.
Anything over 70 mph on the highway is also going to put you under 16mpg.
Subtract more for hills.
Good luck.
Originally Posted by PJB4x4
My truck only gets 12.5-13.7 mpg no matter if its mostly highway or a mix of city and highway and its all stock.
Not normal... Do you either have a lead foot or frequently drive in a hilly areas?
I average 14-15mpg around town and 17-19mpg highway and even better on long trips.
Old Mar 28, 2009 | 11:31 PM
i was thinking about putting my stock intake back on for awhile but then of course i cant use the gryphon
but i can see if it helps any
Old Mar 28, 2009 | 11:37 PM
Old Dogg™'s Avatar
you don't have a stock performance setting?
If you change anything burn a tank or 2 of gas so the computer relearns changes.
I have read that disconnecting the battery is no better than just driving with changes since the truck has to learn anyway.
Old Mar 28, 2009 | 11:39 PM
dont believe i do
i think i only have 89 performance, 89 towing and 91 performance
Old Mar 28, 2009 | 11:50 PM
Old Dogg™'s Avatar
dont believe i do
So you are saying that all your tunes are for the cai and exhaust setup only?
Old Mar 29, 2009 | 01:08 AM
that is what im saying
Old Mar 29, 2009 | 01:16 AM
Old Dogg™'s Avatar
Stock is worth a try to see what you got... but you still will not really be stock if you take off the Cai and tuner....you really need a few dyno runs unless you just like the sound better than the mileage.
Good luck.
Everything has a price...
