07 SCrew clunk in rear at 8K miles? Any Known TSB's?
Old Mar 22, 2009 | 10:55 PM
jsb's Avatar
jsb
Question 07 SCrew clunk in rear at 8K miles? Any Known TSB's?
Hello all,
I've got a 2007 F150 SuperCrew with 8-9K miles on it. I've started to notice that during a low-speed (1-2 mph), slight to medium right-turn, I hear a clunk that sounds like it is coming from the rear passenger side of the truck. It can also happen just after shifting into drive and making the same aformentioned slight-right turn. It is like a small amount of frame-flex from a slight right-turn can cause the clunk when just starting to move.
I know there is a balance weight at the top of the rear driver side frame rail, but I don't think the sound is coming from that. And the last I checked, the spare was snugly mounted.
So I was wondering if anyone knows of any TSB's about any rear spring, rear-end, or driveline/differential/universal joint issues common to these model/year trucks?
2007 F150 SuperCrew
5.4 Liter V8
Automatic with Center floor console shift
6.5' bed length
20" wheels
Truck is completely stock
Thanks in advance for any help.
JSB
Old Mar 29, 2009 | 11:24 AM
texas4life's Avatar
I have an 08 with 13k on it, the same set up as yours, and it does the same thing sometimes when making a right turn on a small incline. I hope somebody knows what it is, or atleast can tell us it's nothing to worry about.
Old Mar 29, 2009 | 12:01 PM
last5oh_302's Avatar
Mine does it sometimes when turning left. My neighbors Lariat (07'ish, round fogs) does it too because I noticed it when he was turning left out of his driveway. I was standing about 100 feet away at the time and I could actually hear it. This is common with almost all 04-08 F150's I believe. I haven't heard what causes it yet.
For those that are going to mention the slip yoke dealio, it's not that at all. This only occurs when turning. The slip yoke deal is a clunk when the tranny is shifting from 1st to 2nd and can be fixed by a simple grease job.
Edit-- it's also not the limited slip differential. This is an entirely different clunk.
Old Mar 29, 2009 | 01:23 PM
jsb's Avatar
jsb
Posted on another forum
On another forum, this was posted:
rear end clunk
I have an 08 with 12k on it and encountered the same problem. I was told it was the drive shaft. The dealership told me the spline (?) was busted on it. They replaced that and put some teflon grease in there and its all better now. I was told there was a tsb on this.
Old Mar 29, 2009 | 01:24 PM
rear end clunk
That's the slip yoke deal I was talking about. It's not the same thing.
Old Mar 29, 2009 | 05:15 PM
Tally TransAm's Avatar
mine started doing it at 13k. been to the stealership 3 times for them to find it and its still there with 23k. i learned to live with it
Old Mar 30, 2009 | 01:26 PM
HDXLT's Avatar
I had one that came in and it was an FX2 s/c too and it turned out to be the leaf springs and it to came from the pass side. But there are no TSB's for it though.
Old May 19, 2009 | 08:34 PM
WhoNeedsReverse's Avatar
My 2004 just started doing this at 30K. It is most prominent when turning medium to sharp left and going slightly uphill. It sounded to me originally like I had a loose wheel or a hub bearing going bad. Its a real cruching pop type noise and does it five or six time through the left hand turn. I took the truck to a parking lot and did donuts at slow speed to have a friend trouble shoot. Neither one of us could pen point the noise. I can make it do the same thing to the right if I really step on the gas and turn pretty hard.
Old Jul 26, 2009 | 09:57 AM
Rubi150's Avatar
I have an 04 SCrew with the same problem. It does it mostley going over bumps and turning left/right at slow speeds. I thought at first my box was loose then maybe my spare tire and it's not. I can't really pin point it. Maybe leaf springs, I don't know. Anyone with some info please help!
Old Aug 9, 2009 | 01:11 PM
vt780htx's Avatar
Has anyone figured this out? I also hear the popping/clunking sound. Had it on my 2005 f150 screw. Truck rides well,only when turning right on a small/steep incline driveway.
GG
Old Aug 9, 2009 | 01:21 PM
Gurt's Avatar
It is the rear leaf springs. THe grease in them has worn out thus causing it to pop. Get some wd40, deep creep, or something and it should stop for a little while. Or I guess you could jack up the truck, spead apart the springs, pack grease in between them, and put it back together. Have yall noticed that if it is raining the truck wont pop anymore? lol
Old Aug 9, 2009 | 02:51 PM
vt780htx's Avatar
Thanks Gurt...i'll give it a try & see what happens. It just rained out today, maybe it won't pop for a day or two. lol GG
Old Aug 9, 2009 | 07:38 PM
SoCalF150FX4's Avatar
My 06 FX4 did this at about 25K. The dealership pulled the rear end a part a replaced the disks in the limited slip. Its been fine since.
Old Aug 9, 2009 | 08:29 PM
risupercrewman's Avatar
GG
I get a small Pop, or Groan under this incline condition sometimes too!....
Old Mar 6, 2013 | 12:04 AM
cmolina07's Avatar
*BRINGING THIS BACK FROM THE DEAD*
Has anyone had a solution for this annoying groan noise the truck makes when going over speed humps and going up hills at an angle....
i have had this problem with my truck even since 2009 and my truck is an 05... hate hearing it everyday. :|
