How the heck do you index your wiper arms?
It doesn't appear that it's possible. Removing the wiper arm is easy enough, but once you remove it there's a tab that has to be lined up to put the arm back on. That tab can't be removed, and the spline part that's still attached to the truck can't be adjusted either. It looks like it's hammered on there for good because the spline part is split at the top which prevents the removal of the spline.
Anybody?
BTW, I did do a search first.
Anybody?
But even if you do pop the tab out, there's no other spot within that circle on the wiper arm that it can go. The section of that circle where the tab is, is the only section of the entire circle without teeth.
You would have to strip off all the splines. I think they are strong enough to hold. Several of them did it back in 2005, never heard a report of a problem.
Won't affect anything. Older vehicles (80s-2000s) used only the splines with no tabs. My '91 Ranger only had splines.
You set it to go over closewr to the pillar? I need to do that, just never wanted to grind the tab off.
You don't need to dremel anything. Just get a screwdriver in there at the bottom of the tab and pry. There was basically no pressure needed. It slid right out. I kept the tab, just incase..
Yes, closer to the pillar. It increases visibility substantially. I especially hated when snow would build up in that area. It created a larger blind spot on the left side of the windshield.
Yes, it will certainly help in rain as well. We've had a lot of rain lately, and I recall it bothering me on my way home from work yesterday as well.
