HIDs
Old Mar 1, 2009 | 04:19 PM
Brandon Miller's Avatar
HIDs
I've done the search on HIDs. I keep getting a lot of mixed info. I'd like to do the HID conversion on my headlights and fogs. What kit and manufacturer do most here recommend?
Old Mar 1, 2009 | 06:15 PM
TJ05FX4's Avatar
This has been discussed to death, but here are the basics.
H13's for the headlights
H10's for the fogs
You have two options with the headlights:
Bi-Xenon - both highs and lows will be HID. Technically the bulb just moves up w/ a motor when you hit the high beams.
Hi/Lo - HID low beams and halogen high beams. Cheaper option w/ less moving parts and worked better for me and my preference.
Xenonlink, Retrofit, and DDM are all very good kits. I went w/ Xenonlink for their known good customer service and support here on this forum. All my questions were answered quickly and the products were delivered as promised.
If you do a search for each of those three companies you will see lots and lots of reviews on all of them.
Old Mar 1, 2009 | 09:31 PM
Thank you for the info. What is usually recommended, 5000K, 600K, 8000K, or 10000K? Is the relay harness needed?
Old Mar 1, 2009 | 09:44 PM
FX4 Matt's Avatar
Registered User
6000K is a good choice very bright white light. I got mine for about 70$ off E-bay from seller hidu4 get all my HID's from this guy 4 sets all are great
Old Mar 2, 2009 | 12:41 PM
freddytran's Avatar
6000K is right on. Anything higher, you will actually lose candle light. Most stock applications will be in the 4300K-500)K range.
For the most part, a relay harness is not necessary. Although the DDM and some other kits will require wire taps to correctly install the heads.
These instructions were perfect - http://www.f-5performance.com/instructions/hidhowto.htm
Old Mar 3, 2009 | 09:40 AM
sivarter's Avatar
xenonlink has no wire taps, just plugs. very easy and good customer support.
Old Mar 3, 2009 | 12:52 PM
http://www.xenonlink.com/product_inf...roducts_id=137
So is this a good kit?
Old Mar 3, 2009 | 12:58 PM
blackjack8900's Avatar
Here is where I am getting mine
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
H-13 heads
H-10 Fogs
6000K
Old Mar 3, 2009 | 06:22 PM
87fiveoh254's Avatar
DDM is completely plug and play.
