tips on adjusting driveline angle
Old Feb 26, 2009 | 09:30 PM
happyabortion's Avatar
oki so i FINALLY decided to do my djm flip kit on my crew cab f150. i got it all installed and going but now im having problems aligning the angles. i suppose its suppose to be easy on the djm kit but i just really have no idea how to get it straight. Plus by myself its tought jacking the car up and down back and forth! so im hoping someone with experience with this stuff can shed some light and help me get my truck on the road! Any help would be greatly appreciated!!
crew cab 05 lariat. djm lowering kit 3.5/5
Old Feb 28, 2009 | 08:24 PM
anyone?
Old Mar 1, 2009 | 12:25 AM
Screw-Me-05's Avatar
Do you have the 2 piece drive shaft or a 1 piece? did you get a pinion shim kit with it? atleast 2* maybe 3*
Old Mar 1, 2009 | 11:52 AM
azmidget91's Avatar
Jack up the back of the truck, just barely loosen the ubolts, try to place jack stands under the leafs if possible, the adjust the angle with the two bolts that go through the flip kit, tightening the front will bring the pinion down tightening the rear will lift the pinion
