Want More Power!!
Old Feb 2, 2009 | 11:57 PM
Spurs06f150's Avatar
i got the airaid poweraid throttle body spacer on mine and it added a bit more power and pick up not to mention a little better on the gas, it makes a little whistling sound though i think its pretty cool some think its annoying
Old Feb 3, 2009 | 12:01 AM
dkgreyf150's Avatar
i would definately go with custom tunes either gryphon or xcal 3 just depends if you want to pay a little more for the display which i love
Old Feb 3, 2009 | 10:30 AM
rms8's Avatar
Originally Posted by ATOM
at least it wasn't a fluke. 200 bucks for a new edge , god i love good deals i loved my edge so far, how bout you rms8?
I suites my needs perfectly. I knew my speedo would be off and that the tranny would be a bit flaky due to that after I installed my 305/55/20's. The Edge obviously allowed me to compensate for the tires by inputing their size. I run the Edge on Level 2 since I'm not about to dump anything but 87 in my truck. Works like a charm!
I am MOST pleased by the display options. Having a race car with several gauges to monitor all sorts of engine parameters is ideal. When I get into my truck, or Neon, or the wifes VW, I feel that I'm at an extreme disadvantage not knowing what's going on compared to my Mustang.
The Edge allows one to display up to four engine parameters simultaneously from a pool of about 15. I set it up to display the Coolant Temp, Oil Temp, Tranny Fluid Temp and the Air Intake temp.
Old Feb 3, 2009 | 11:04 AM
05supercrew's Avatar
Gears will help also.
Old Feb 3, 2009 | 11:09 AM
JeremyGSU's Avatar
I've got intake, exhaust, 4.10 gears, and custom 93 dyno tunes from VMP and I still find myself wanting more power. The power bug is hard to get rid of.
Old Feb 3, 2009 | 12:50 PM
agadawg1717's Avatar
http://www.hypertech.com/
How does this Max Energy compare the the Gryphon?
Old Feb 3, 2009 | 01:03 PM
jlstang351's Avatar
gryphon will be custom tuned to your truck...Just the difference in the Edge and the Gryphon was night and day...Like the others said, the display is a nice piece w/ valuable information....
Old Feb 4, 2009 | 09:09 AM
Veteran: Army
it whistles 'cause it's restricting your airflow, the only thing you did was successfully lightnened your wallet
agadawg1717 a custom tued tuner will always outperform a canned tuner I had a hypertech and moved on to an Xcal2
Old Feb 4, 2009 | 07:26 PM
dkgreyf150's Avatar
i have had both, i changed from hypertech to gryphon i like the display of the gryphon but performance wise i couldnt tell much difference but that was with canned tunes in both but i expect that the customs tunes will make the difference
Old Feb 9, 2009 | 09:27 PM
Got the Hypertech max energy today. Still have some adjusting to do, but so far so good.
