MBRP exhaust help
Old Feb 1, 2009 | 03:16 PM
alex06's Avatar
MBRP exhaust help
To anyone who has installed the split rear kit can you take a pic of the hanger on the driver side in the rear the one you have to mount to the frame that they send you.
I can not figuere out how to do it.
Also the passenger side last tail pipe piece they flared the wrong end of it so have to give them a call to send me a new one.
Old Feb 1, 2009 | 04:42 PM
Ballin STX's Avatar
I just have the SI/SO but I called with just a quick question and the customer service is VERY good, so that would be the first think i would do.
Old Feb 1, 2009 | 10:44 PM
fitz888's Avatar
Si/so hear to,they sent me the wrong hanger but like ballin said customer service is very good they sent a new one right out. I think it was autoanythings mistake but they took care of it.
Old Feb 2, 2009 | 08:56 AM
Smokewagun's Avatar
It's a pain because you have to stick your finger in a hole in the frame to hold the nut while you thread the bolt. Poorly designed in my opinion. you may be best to get one of those nuts welded to the spring clip to hold the nut hile you thread into it. It's really easy to lose a nut inside the frame... never to be seen again.
Smoke.
Old Feb 2, 2009 | 06:37 PM
alex06's Avatar
thanks just what I needed.
Old Feb 2, 2009 | 06:41 PM
07 Crew's Avatar
Smoke.
That hanger looks weak
Old Feb 3, 2009 | 12:55 PM
alex06's Avatar
what do you mean weak?
Old Feb 3, 2009 | 01:03 PM
jalichoacan's Avatar
no muscles
Old Feb 3, 2009 | 01:16 PM
alex06's Avatar
weak as in gunna break or weak as in don't look so good.
Old Feb 3, 2009 | 07:49 PM
GTRider245's Avatar
I would fully expect that hanger to break.
Old Feb 4, 2009 | 07:53 AM
Smokewagun's Avatar
Not even close. I thought so, too... at first. The rubber bushing is tougher than the factory ones, and that metal tab that looks flimsy, well, you'd have a hard time flattening it in a vice. It is a great set-up... for holding - just a !@#$%^ to install.
