what kind of tools to install running boards?
Old Jan 14, 2009 | 09:02 PM
jefh's Avatar
I found a guy that is selling his running boards off a truck he is returning, He wants $100 for them and told me that he'll let them go cheaper if I remove them myself, and was wondering, what kind of tools do I need to remove them?
He lives about an hour away from me, so I want to have everything I need when I go get them
socket wrench? what size are the sockets?
thanks in advance
Old Jan 14, 2009 | 09:18 PM
bjp207's Avatar
not sure on the size of sockets, I would definetely take safety glasses because you will for sure get dirt in your eyes, and I actually had to cut 4 of my bolts off with my dremel...might need that...I only had mine on the truck for one winter and the slide nuts boke and were spinning freely
Old Jan 14, 2009 | 11:43 PM
IDNC76's Avatar
yeah just a few different sockets was all it took
extra set of hands is nice too
also your prolly gunna want a breaker bar, for those stubborn rusted bolts
and safety glasses is a great idea, sounds silly, but you ll be amazed how much crap will fall on you
Old Jan 14, 2009 | 11:52 PM
06yz250f's Avatar
oems i believe are a 12mm. like 8 bolts on each side really simple. takes 20 minutes to install
i took off some aftermarkets and they were 13mm or 14mm.
but basic hand tools is all you need
Old Jan 14, 2009 | 11:53 PM
JHens4's Avatar
i wish the 04+ ones fit on 01-03 screws
Old Jan 14, 2009 | 11:54 PM
Shinesintx's Avatar
I second the safety glasses Learned the hard way
Old Jan 14, 2009 | 11:55 PM
JHens4's Avatar
same here, $8 for some good safety glasses is better than a $300 trip to ER for metal in eye
Old Jan 14, 2009 | 11:58 PM
IDNC76's Avatar
its good for , it builds character
Old Jan 15, 2009 | 11:58 AM
mkosu04's Avatar
I'd take some rust penetrant spray along... as soon as you get there hit all the bolts with a good spray.
Maybe take a pipe wrench in case you end up rounding one of the bolt heads... you could use that to maybe get the bolt off (or break off the head)
And, as said before, a full set of sockets and your biggest bar
Old Jan 15, 2009 | 12:35 PM
ATOM's Avatar
make sure to have a screw driver too, those u-nuts are a tiger to get off. i got the same steps, if it wasn't -18 out, i'd look more into it
Old Jan 15, 2009 | 01:39 PM
mSaLL150's Avatar
12mm bolts. i definitly got rained on by dirt, wearing glasses or goggles is a must.
Old Jan 15, 2009 | 01:53 PM
Jpaye's Avatar
sockets and a flat head to get the nut tab things off! very simple. You might also want to have someone to catch the step before it falls down too
Old Jan 15, 2009 | 01:57 PM
08 silver xl's Avatar
I bought a new set that look like the ones in your picture. Put them on my 2008 f150 in 20 minutes. The clips are the special part. Take ALL the clips in the body. Use Liquid Wrench and spray them good, let it soak in (about one or two beers) The bolt size is metric. Last guy said 12mm, I think its right but take a metric socket set. Some post say the Ford tubular boards rust easy.
Jerry
