Biggest tire with leveling kit FX4
Old Jan 10, 2009 | 06:55 PM
Mike_fx4's Avatar
I have a 2004 FX4 with the stock 18inch wheels. Im getting ready to install a 2.5 leveling kit and wanted to know the biggest tire i could put on my factory rim with a aggresive look. if you can post some pictures or hit me with some tires sizes! thanks a lot
Old Jan 10, 2009 | 07:01 PM
thirdgenbird's Avatar
if you do a search, there's tons of threads on this...
a 35 12.50 will slightly rub:
Old Jan 10, 2009 | 07:08 PM
brianjwilson's Avatar
Welcome to the forum.
This same thread gets posted probably atleast once a day, look around a bit.
35x12.50R18 BFG KM2's on stock 18" wheels, no rubbing with Bilstein 2" leveling kit.
Some tires will rub due to side lug or slightly different sizing. A lot of 35's will rub the lower control arm at full lock. Some will rub the upper control arm with big tread on the sidewall. Aftermarket wheels change everything...
Old Jan 10, 2009 | 07:12 PM
Mike_fx4's Avatar
I was thinking about going with the tires you have on your white truck there and just adding a 1/4 inch spacer on my stock rim to kick it out a little bit, do you think that would work ok ??
Old Jan 10, 2009 | 07:24 PM
should work fine
Old Jan 10, 2009 | 07:53 PM
Mike_fx4's Avatar
has the 35s changed your mpg
Old Jan 10, 2009 | 08:30 PM
thats a big 10-4
i have a 4.6 and 3.55s and it has killed my highway miles. i'm re-gearing this spring if all goes well.
Old Jan 10, 2009 | 08:44 PM
315x70x17 BFG AT's on 17x9 American Racing Crater wheel's. http://
Old Jan 10, 2009 | 09:19 PM
Djacobs28056's Avatar
Anyone know the widest tallest tire you could fit on a 17" OEm rim? I have leveling kit and AAL.
Old Jan 10, 2009 | 09:20 PM
duder's Avatar
this is with 33x12.5x18 toyo open country. no rubbing and still get about the same gas mileage
Old Jan 10, 2009 | 09:41 PM
06yz250f's Avatar
ok im just gonna say this and clear up every question.
stock wheels= 12.5" wide tire max
2wd w/ 2" leveling= 33/12.50"
4wd w/ 2" leveling= 35/12.50"
if you add 1/4" spacer you might not be able to run the 35's, it can cause more rubbing, you can try it but expect slight rubbing.
Old Jan 10, 2009 | 09:53 PM
05RedFX4's Avatar
I totally agree. Just to clarify even more, the stock 17" and 18" wheels are only 7.5 wide, so it makes for a tight sqeeze getting a 12.5 tire on a 7.5 wheel. The stock 20's are 8.5 wide so if you push it you could probably get a 13.5 on them.
Old Jan 10, 2009 | 10:39 PM
Mike_fx4's Avatar
anyone have any pics of a 04 up running a 305/65/18 on the stock fx4 rim ?? post them if you do ! thanks
Old Jan 10, 2009 | 11:12 PM
Mike_fx4's Avatar
Or just post some pics of 33s and 35s on stock wheels! thanks
Old Jan 10, 2009 | 11:20 PM
JNC995's Avatar
https://www.f150online.com/forums/wh...ims-tires.html
That should keep you busy for a couple days. If you can't find what you're looking for in there. Then it probably doesn't exist.
