Paint chipping on painted Roush grille
Old Jan 7, 2009 | 09:48 AM
Stiffhorn99's Avatar
Sanded the grille with 400 paper, used Kylon fusion satin black. Started to chip almost right away and is getting worse day after day.
Did I do something wrong?????
How is your painted grille holding out?????
At this rate I will be repainting every month.
Old Jan 7, 2009 | 10:15 AM
verifine-f-150's Avatar
im in the same boat tried doing it myself with no luck got it professionally painted and its starting to chip also. If this doesnt work im gonna get it line-x'd
Old Jan 7, 2009 | 10:28 AM
Talked to the line x shop, they said they would have a little better luck with it sticking but given time it would chip just as bad as paint.
Said he would do it but it would be like throwing money away.
Phoned Roush they said they have no plans to make a black one for our trucks.
Old Jan 7, 2009 | 10:55 AM
IDNC76's Avatar
i sanded mine with 600 grit i believe, and i used a whole can of krylon fusion, and mines holding up very well
Do you drive on the highways alot ?
i always notice 1 or 2 chips , after traveling on the highway
but around town, it holds up fine
Old Jan 7, 2009 | 11:05 AM
Ya I did alot of highway over the holidays. Still was hoping for alittle better result. I'm on the highway aleast once a month and that still means repainting once a month or the grille looks like a POS.
Old Jan 7, 2009 | 11:25 AM
Tylus's Avatar
have you guys tried using a plastics paint? gotta remember this grille is plastic and it will see some movement/flex.
a plastics paint should adhere better, and be more pliant
Old Jan 7, 2009 | 11:38 AM
SteveVFX4's Avatar
The Krylon Fusion paint is for plastics. They advertise that no sanding or priming is necessary.
Maybe in this case a special plastics primer that promotes adhesion would be beneficial?
Old Jan 7, 2009 | 02:04 PM
Considering they are painting chrome I believe that's where the paint is chipping.
Old Jan 7, 2009 | 04:00 PM
so does everyone eventually repaint theres i just got mine done and installed last night and somehow managed to get some chips last night after driving only two miles
Old Jan 7, 2009 | 04:37 PM
IDNC76's Avatar
yeah, i dont think theres anyway around rock chips
i havent had to repaint mine fully yet, just do small touch ups
Old Jan 7, 2009 | 10:43 PM
Tylus's Avatar
there are a few basics to painting stuff. you guys have got me wondering if y'all are doing them
1. Prep the surface
2. Clean using a solvent that leaves no residuals
3. Primer with a good quality undercoat
4. apply topcoat
5. apply clearcoat if necessary
the krylon stuff is good stuff, but it's only as good as the base layer. and if you're going straight ontop of the slick plastic chrome, it stands to reason it's flaking off. Nothing really there to adhere to
Old Jan 7, 2009 | 11:53 PM
josh34's Avatar
i used the clear primer .. adhesive promoter first and mine is holding up good
Old Jan 8, 2009 | 12:36 AM
Mach-1's Avatar
Sanded mine with 220 grit. Sprayed it with adhesion promoter. Painted it with PPG 9000 Black, DXR 80 hardener and reducer. Been painted for about a year and a half with no chipping or peeling.
