HID Conversion kit
Old Jan 5, 2009 | 04:28 PM
bigdog87's Avatar
HID Conversion kit
I have the conversion kit in, but I've had a very hard time finding a place to mount the ballast. I was just curious if anyone had dealt with this and had pictures of where they mounted theres. Thanks.
Old Jan 5, 2009 | 04:38 PM
freddytran's Avatar
If you look through the opening behind the headlight, on the other side, there is a vertical L-shaped bar. I mounted mine there. I also drilled a hole in that bar so I could run a couple of zip ties to tighten it down.
I know others have used the 3M supplied tape to mount it right on the back of the headlight. Hope that helps.
With the fog lights, there is another vertical bar to the outside of the fog lights. I cleaned it well with an alcohol prep pad and used the 3M tape there, and I then used a couple of zip ties to tighten them down.
Old Jan 5, 2009 | 09:07 PM
bigdog87's Avatar
Thanks man, I'll check it out tomorrow and see what I can do!
