Keeping sandbags in place
Well starting from the left the #1,2,3, and 6 axles lift when a switch is activated in the cab so it can turn when empty, and the #1, 3 and 6 axles lift when a switch is activated to turn when loaded.
Hi
I loaded up my pickup with a half ton of sand to spread out on my icy driveway.Used about 500LBS of sand on the driveway&the rest left in the truckbed.Truck rides very stable.4wd works good in the snow....Pete
Your 4x2 works equal to a 4x4, when you simply add weight? So, by that rationale, if I add 3/4 ton of sand in my 4x4 bed, will mine be equal to a 4x6? Sweet, I'm gonna go try it. Now nothing will stop me!
ETA: I pulled an AWD SUV out of the mud this evening, without spinning a tire. With some sand, maybe I can drag a tank around.
So you guys say if adding sand doesn't work... then why is it when my buddy's truck 4x4 truck got stuck in 1 foot of snow and didn't after adding a few of my sandbags work without the use of a shovel? And why has it been a daily practice of many people up here in the NE for the longest time for the winter months? It works...
For the snow ball's chance you are being sincere, I don't think anyone is necessarily saying that adding weight to the bed of a pickup doesn't aid traction. It is your gross exageration of the benefits of doing this, and actually saying it is as good or better than 4wd, that causes most of us with a brain, to see that you are doltish.
Ya know, I am a member of many forums, and I always try to be courteous to people. But I have to say, you truly are IQ challenged. You don't even understand why people give you a hard time. I am still leaning towards the notion that you post these ridiculous notions for effect, because no one I know, can be that dense.
I can tell you after he borrowed my sand bags, he swore up and down and kissed my feet for helping him the easy way.
you buddy was more careful after finding the limits of his truck, weight helps but experience is much more important ive been in 2 feet deep of snow with my lowered truck no extra weight and was perfectly fine 1 foot of snow is nothing. also as to why he got stuck and not you....id be willing to bet you have different size tires, different brand tires, different stock weight, and a different iq....i could go out in my truck in 2 feet of snow play around and not get stuck then hand the keys to my gf and she will be stuck instantly
