bambi mod on an 08??
Old Dec 22, 2008 | 07:17 PM
08Fx2rider's Avatar
anyone done the bambi mod on an 08 F150? i have HIDs and they always run on highbeam so i need to do the bambi mod so my fogs work but i wanna make sure it works for the 08s also...thanks
Old Dec 23, 2008 | 09:19 AM
08Fx2rider's Avatar
nobody? any ideas if it will work???
Old Dec 23, 2008 | 09:23 AM
harly4d's Avatar
If you're HID's only work on high beam - you wired it up wrong. A simple swap of the wires would fix your problem. No mod needed.
Old Dec 24, 2008 | 07:31 AM
mkosu04's Avatar
if by "bambi mod" you actually mean "Fog light mod" then perhaps you should say that and then you will get a response.
Yes, I believe there are people that have done the fog light mod (so the fogs stay on when your high-beams are on) and it worked for them.
Old Dec 24, 2008 | 01:13 PM
08Fx2rider's Avatar
i know the mod works. im asking if anyone has done it on an 08 because the fuse is different. and in other threads and forums the "fog light mod" is referred to as the "bambi mod"
