Level it?
Old Dec 3, 2008 | 10:01 PM
  #31
rabbit hunter's Avatar
Here is the step by step process posted by another member.
https://www.f150online.com/forums/su...t-install.html
Old Dec 3, 2008 | 10:56 PM
  #32
mSaLL150's Avatar
Originally Posted by Tylus
I hear those 2 statements all the time. My ball joints are bad because of the leveling kit...and that the stock shocks are crap. IMO, they work great. It's a truck with a rough ride. The stock shocks stop all body roll and bounces with the first bounce.
seeing posts like that, it really makes me wonder. I am a very **** retentive driver. I avoid every bad section of road that I can. But then I see 9/10 people "deliberately" hit that pothole I just avoided.
I have zero problems with the kit...and there are tons of other people the same way. I think the roads we drive on are a bigger factor, and so is the drivers ability to avoid road obstacles....most people just blindly plow through anything
either way, msalle, we'll just have to agree to disagree. A leveling kit is perfect for the trucks that see little to no offroad action...I agree though that a lift kit is the "right" way to do it...if you 4x4 alot. Otherwise, you are blowing a ****-ton of money to "Do it right"
unless you are after a certain look...which I am coincidently...hopefully my f-150 will be lifted within the next few months
both
the front goes up 2 to 2.5" taller...and the rear bumper will go downwards by about 1"
Sweet man, cant wait to see it lifted. I want to get a Roush charger for mine
Oh and believe me, i dont deliberately hit potholes. Theres a reason my truck is almost 95k miles old with almost zero issues. But some of the county roads out here are incredibly old and are littered with DEEP potholes that often times you cannot see or avoid without swerving out.
And the stock shock ares great for the first 15k miles or so. But once they go bad, heh, they are BAD. As with most shocks that go bad though. Just wish they would've lasted longer, thats all.
Old Dec 4, 2008 | 06:18 PM
  #33
Penguin86's Avatar
next question is what do you think the odds are of the front sitting higher than the rear when i put on the 2.5" spacer?
i'm thinkin maybe i should have went with the 2" spacer since i won't be able to buy an AAL if the front does sit too high...
Old Dec 4, 2008 | 08:22 PM
  #34
mSaLL150's Avatar
I think you will be fine. The 2004 model had ungodly rake, my truck stock was more like 3" difference between rear and front. You will be happy with 2.5" of lift.
Old Dec 4, 2008 | 10:09 PM
  #35
bjp207's Avatar
You'll be fine, mine had a rake like yours when I got it, and with the 2.5'' AS it was perfectly level...maybe 1/4'' higher in the rear...AAL just jacked it up about an inch in the rear
Old Dec 4, 2008 | 10:30 PM
  #36
Ballin STX's Avatar
Originally Posted by 06yz250f
i hate how my dads truck drives with that spacer now, everyone says ride quality doesn't change, but IMO on his truck it did. speed bumps are much more harsh now and i feel much more out of the front end. his is the only leveled truck i have driven tho, so thats just my opinion on his truck
Man i cannot agree with you more, After i had the leveling kit on for 15k miles on my 05 f150, every bump i hit was just ridiculous, I was surprised how bad it was, now on the new truck i am saving up to get the bilstein leveling shocks all i have heard is good things about those shocks!
Old Dec 4, 2008 | 11:29 PM
  #37
mSaLL150's Avatar
Didn't you get a 4x4 this time? Get a suspension lift. It will ride the best.
Old Dec 4, 2008 | 11:36 PM
  #38
yetti96's Avatar
My '04 has a 3-1/8" difference between front and rear. Once my 2.5" AS goes on I will re measure.
Old Dec 5, 2008 | 12:59 AM
  #39
Ballin STX's Avatar
Yeah, i got an 08 4x4 stx ext.
I wish I could but I know I would need gears with a lift kit, and I dont wanna void my warrenty, but I wish I did.
Old Dec 5, 2008 | 10:19 AM
  #40
Big Slick's Avatar
yep, after 50K miles, the stock shocks are junk. i'll be getting the 5100's for xmas to level the front. i figure i need shocks anyways so why get a spacer and replacement shocks when i could get the 5100's and kill two birds with one stone.
Old Dec 5, 2008 | 10:28 AM
  #41
hivoltagefx4's Avatar
You should be ok, I am using a 2.5" AS kit on my FX4 and sits level.
Old Dec 5, 2008 | 10:55 AM
  #42
07FX4Chick's Avatar
I am too, and it is perfectly level.....
Old Dec 5, 2008 | 11:15 AM
  #43
last5oh_302's Avatar
I measured my 05 from the hub (top of center cap) to the bottom of the fenderwell.
Front is 24.5" and back is 26.5".
If I used a 2.5" leveling kit I believe the nose would be sitting higher than the back.
I think a 1 3/4" leveling kit would be perfect. I'd like me truck to sit just a smidgeon higher in the back so when I have any weight in the back, or I'm towing, the truck doesn't look like a sagging Dodge.
