Remote Start/Keyless Entry ?'s
Old Nov 19, 2008 | 11:39 PM
heckdogg's Avatar
Question Remote Start/Keyless Entry ?'s
I am trying to install a remote start with keyless entry on my 05 (with factory keyless entry) what wires & were has everyone tapped into to use the remote start key fob with the factory keyless entry?
Old Nov 20, 2008 | 12:06 AM
SteveVFX4's Avatar
Do you have a wiring diagram for your truck?
If the remote start has keyless entry built-in, then you just tap into the door lock (pink/yellow) and unlock (pink/green) wires and it should work with the remote start keyfob. Those wires should be near the driver's side kick panel.
What system are you trying to install?
Old Nov 20, 2008 | 11:34 AM
heckdogg's Avatar
Steve,
I do not have a wiring diagram. I am installing the Bulldog 500 remote start. Their wiring tells me to connect to the pink/yellow and the pink/green wires in the driver's kick panel, but when I connect to those wires I found there, the keyless will not work.
I am debating removing the back seat to tap into the BCM for the keyless, has anyone here done that?
Old Nov 20, 2008 | 12:27 PM
Low_e_Red's Avatar
No, Just make sure you have the correct pink/yellow and pink/green. Grab a meter and test.
