Need Advice
Old Nov 14, 2008 | 02:00 PM
MrAggie1982's Avatar
Need Advice
Hi all,
I just replaced my stock headlights with harley ones and on one of the lights the little plastic tab broke off ( the one that you lift to get the bulb out) my question is what should I do? Will it be ok if I leave it like that ( the light works) or do I need to do something to fix it?
Jon
Old Nov 14, 2008 | 02:18 PM
thirdgenbird's Avatar
if your talking about the one that is there to pull the "pin" out of the radiator support you will be fine. you will just have to use a flat screwdriver or pocket knife to pull the tab up when you change your bulbs
Old Nov 14, 2008 | 02:20 PM
I meant the one when you pull the actual turn signal bulb out of the connecter. The orange connector. you pull up and then pull the bulb out. When I pulled up the cheap little plastic broke.
Old Nov 14, 2008 | 02:49 PM
i still think you should be ok. the light still seals and they are an interference fit so it should not fall out
