Ethanol?
Old Nov 7, 2008 | 11:45 AM
enggass's Avatar
Ethanol?
What can you guys/gals tell me about Ethanol in my Truck.
Here in Maine, as of this week, most gas stations will be selling gas containing 10% Ethanol. They mention a 3% loss in fuel efficiency, and for pre- 1980 vehicles, engine component incompatibility.(seals, hoses, etc.)
We weren't givin a choice... I'm sure we aren't the only ones.
Steve
Old Nov 7, 2008 | 05:01 PM
Tylus's Avatar
ethanol cause alot more than 3% loss in MPG. try 2-4 mpg less per tank when you use ethanol blends
across the country, in the Oct/Nov time period the gas stations start running a "winter" blend gas. It typically has more ethanol. sometime in the spring, the "Summer" blend will come back...around March/April.
ethanol is very corrosive and eats plastics/rubber. That is the incompatibility. It's also why only the FFV F-150 should run E85. The FFV has different seals to keep the Ethanol from eating 'em up
Old Nov 7, 2008 | 05:09 PM
Penguin86's Avatar
all gas stations here have 10% ethanol in the gas year around...
Old Nov 7, 2008 | 05:43 PM
NoLongerJeepin's Avatar
Steve
Minnesota has been running a 10% ethanol blend for quite some time now. My truck never had any issues with it, and my mileage has always been around 18mpg hwy.
E85 on the other hand can cause a ton of problems, and kills mileage. You might save $0.40/gallon buying it, but you lose money in the long run due to crappy MPGs. E85 will cause horrible corrosion in pre-1980 vehicles.
Old Nov 7, 2008 | 06:35 PM
rms8's Avatar
What to know about Ethanol
Steve
Here are the plain and simple facts regarding ethanol :
Ethanol is corrosive to BARE aluminum.
Ethanol is incompatible with rubber seals. Silicon seals are fine with Ethanol.
Here in IL, when gas was $4+/gal , E85 was $2.90-3.15/gal. The delta between the price of gas and E85 increase dramatically when the price of gas goes up. At the present, Gas here is $2.20 and E85 is $1.90. Not as dramatic a difference as when Gas was $4 or more a gallon.
If one has a FFV, they benefit by using E85 when the price of gas is really high, but when the price difference is not as much, then you will get better $$ per mile with gas.
BTW, ALL gas in IL is 10% blend, as it is in most Midwestern states. No big deal. 10% isn't anything to be concerned with.
