Did a Bad Thing
Did a Bad Thing
involves my truck and a power washer. long story short i was blastin bugs on my bumper and front of truck when all the sudden a big patch of paint blows right off the fiberglass part above the bumper. really sux i have no idea what it will cost to fix it. does anyone know the correct name for this piece or even a part number? again its the fiberglass piece above the bumper and below the headlights.
is it the bumper pad? i think thats what its called. just take it to a paint shop and let them paint it. we just had to have my sisters tailgate re-painted. (some A-hole put F U in everybody's car in our apartment complex, thank god i wasnt home yet)
It's called the upper bumper cover and it's plastic not fiberglass. If you still have warranty left, take to the dealer and have them repaint it. If the paint came off from pressure washing, then it obviously was not prepped properly from the very beginning. Ther is special steps that is needed to paint plastic and if not done, or done incorrectly, the paint will peel. Chances are your entire upper cover will need to be repainted cause more than likely the prep job is bad on the whole thing. Also check your grill surround (the painted part around your grill) it's also plastic for any paint defects.
P.S. If you take to the dealer to get it repainted, it happened while you were in one of those self serve coin operated car washes.
[QUOTE=05RedFX4;3409071If you still have warranty left, take to the dealer and have them repaint it. If the paint came off from pressure washing, then it obviously was not prepped properly from the very beginning. Ther is special steps that is needed to paint plastic and if not done, or done incorrectly, the paint will peel. Chances are your entire upper cover will need to be repainted cause more than likely the prep job is bad on the whole thing. Also check your grill surround (the painted part around your grill) it's also plastic for any paint defects.
P.S. If you take to the dealer to get it repainted, it happened while you were in one of those self serve coin operated car washes.[/QUOTE]
Even if you are out of warranty take it to your dealership. This happend to my wife's Pontiac four months after the warranty ran out. GM knew they had a problem with this model so I didn't have any hassel and when I spoke to the paint guy he said it the plastic wasn't prepped right prior to painting. They ended up painting the entire frontend to make it right. No problems since and the dealership paid for it all.
really hope i can get lucky (it is still under warranty) gonna take it to the dealership tomorrow. called today just to find out how much the part was... 245.00 and its paint to match so thats without paint and labor
. only reason i think they may question it is the actual pressure washer made some fairly good cuts in the plastic as well so its 50/50 i guess.
dont tell them you used a pressure washer if its not obvious. just say you realized paint was missing on the bumper and there is no reason it should be like that.
. only reason i think they may question it is the actual pressure washer made some fairly good cuts in the plastic as well so its 50/50 i guess.my dirtbike has never seen a pressure washer since the water pressure will get water in places you dont want it to.
Same situation: live in s.e. TX and love bugz so thick you'd have to be careful opening your mouth outside lest you get a mouthful...
I couldn't wash my truck for almost 2 weeks after Ike (no power) and by the time I could wash it again, they'd already done a number on the bumper cover.
So my well-meaning husbandperson took his pressure washer...the one for washing the house...yep, you can guess the end result. He was afraid to tell me, he thought I'd be livid. But I'd planned to get it repainted anyways, already checked and around here it'll cost me about $250 to remove and repaint...I thought that was a decent price, what do you think?
