Weird Radio Problem
Weird Radio Problem
With key in ignition and engine off, the radio works perfectly fine. However, as soon as I start my truck, the reception goes bad. Seems like my antenna may be unshielded or something? I'm not electronically savvy, so I'm not sure where to start troubleshooting. Anyone else have a similar problem and know of an easy fix?
It's a stock headunit, audiophile with subwoofer. I can play CDs and music off my iPod with no issues.
on the front of the engine (both sides) there are 2 radio capacitors. the drivers is on the bracket for the air intake and passengers is same spot other side.
they look like a 1"x1" plastic square and about 1/2" thick
check out page 21 for a picture of them
check to see if these are okay
I also notice it when my kids play the headrest dvds through the radio. They pretty much are stuck with using the headphones because the reception sucks so bad. Do you have any aftermarket electronics wired in your truck... remote start, alarm or something else. I always wondered if any of that stuff in mine could be the cause. I had my remote starter/alarm installed a week after I bought my truck. I know Ford has a TSB on splicing wires in our trucks for some reason. I doubt the shop that installed mine new anything about it.
I have an XM Commander and a Viper Alarm, but my radio worked fine until just a few months ago.
Tylus, I'll check the capacitors, but not sure what those are supposed to do? I thought the capacitors just let the radio run for awhile with the engine off? Not sure how they would affect radio reception.
