How soon to change oil?
Old Oct 8, 2008 | 12:07 PM
ToofastFX's Avatar
At what mileage would you change the oil on a brand new f150?
Old Oct 8, 2008 | 12:11 PM
There is no break-in period or no break-in oil anymore, so just at whatever interval you plan on changing it normally. I change mine between 3500 and 4000, usually about 3800. I take it to the dealer as they do it for about $25, and I want Motorcraft 5-20 and a Motorcraft filter.
Old Oct 8, 2008 | 12:24 PM
I do the first oil change on all of my new vehicles at 500 miles, my second at 1500 miles, and my third at 3000 miles. From there on out I change the oil at 12 months or 3000 miles -- whichever comes first.
Old Oct 8, 2008 | 02:49 PM
Tylus's Avatar
500 to 1,000 on a new motor. that crap was dirty as hell in my truck.
afterwards, I follow the 3,000 mile rule. sure you can follow the 5,000 mile recommended interval, but oil is cheap...engines aren't
Old Oct 8, 2008 | 02:57 PM
dkstone05's Avatar
x2
That and I sent an oil sample to blackstonelabs at a 4,000 mile interval mostly city no towing or anything else and they said do NOT go any further. This is with M-craft oil so I call BS on Ford advertising 5,000 mile intervals anyway.
Same oil and filter in my wifes Honda(yes I said Honda) Blackstone said to at least try 5,000 miles if not more.
Old Oct 8, 2008 | 03:01 PM
scott1981's Avatar
I do it after the first 1000 mi then go to my normal interval
Old Oct 8, 2008 | 05:28 PM
DARK KNIGHT08's Avatar
With the newer vehicles(with the use of Synthetic oil) abidding by the 5000 rule is fine, unless the oil level gets low before that mileage point. I did my first oil change in the truck at 5000. I would recommend anyone not using synthetic oil stick to the 3000 rule.
Old Oct 8, 2008 | 06:13 PM
BlueOvalFitter's Avatar
Thumbs up
I wouldn't go no more then 3K miles!
Old Oct 8, 2008 | 09:38 PM
kjohnson1's Avatar
I agree with everyone else. I ALWAYS do my oil changes every 3000 miles. The only car I had that I changed every 5000 miles (the recomendation) was my 1997 Lincoln Mark VIII. I only used Mobil 1 in that car and changed it every 5000 miles because you needed 3 elbows, remove the power steering lines from the k-member and a whole lot of patience to get the filter off. I was only WILLING to do it every 5k miles.
Old Oct 9, 2008 | 07:06 AM
Average-Joe's Avatar
My 08 states every 8000 miles oil change(Synthetic) but i'm doing the first change at 5000 or at 6 months.
Old Oct 9, 2008 | 09:41 AM
ToofastFX's Avatar
Doing it this afternoon. I'm currently at 3300 and I took delivery Aug 1st!
