Holy Crap!!
Old Sep 5, 2008 | 07:27 PM
  #31
Ftruck05's Avatar
The 'burban was the first I've ever seen/heard of this happening. I've done my own brakes since I was 16 and never had this happen....Let's see. 89 jeep YJ, 92 Ford Ranger, 03 Ford Ranger, 03 F150
Old Sep 6, 2008 | 04:07 AM
  #32
code58's Avatar
Originally Posted by Clifford4x4
Guys need some advice.. my wife's explorer just had its brakes done 3wks ago. we went on vacation and it started making a grinding sound. she drove it anyway for the rest of this wk. I take the wheel off and see that the wheel was actually rubbing the brake caliber, i go to man handle the caliber and it falls off! The ford shop forgot to put the bolts that hold it to the rotor My wife has been driving w my 3 yr old for a wk, this could have been a disaster!
What do i tell the idiots at the service department in the morning?? This sucks and not to mention my wife has to drive my truck to work which is like 120 mile haul
Sounds like they did something wrong but the caliper generally doesn't have bolts to hold it to the caliper frame because it has to slide crossways as you apply the brakes and as the pads wear. There are different arrangements to hold the caliper assy. in the caliper frame (the bolts are in the frame, not the caliper), but your frame still appears to be attached (bolted on). I am not specifically familiar with how the caliper piston assy. is held in the frame on an Exploder, hard to imagine how they could have missed putting the slide shims in (what probably holds the caliper tight in the frame), they must not have put the small bolt that keeps the slide shim from from sliding in. I have frankly never put Locktite on that bolt- if tightened properly I don't think it's necessary.
Old Sep 6, 2008 | 07:49 AM
  #33
bjp207's Avatar
The caliper bolts to caliper slides which slide in and out of the frame as the brakes are applied
Old Sep 6, 2008 | 11:10 AM
  #34
Clifford4x4's Avatar
well guys everything is fixed up, took it there, he was apologetic(sp). He put me new brakes pads on an again apologized again. He said he's never seen both bolts fall out and somebody obvisously didnt do there job, he went straight back there and had a team meeting which made me feel better. I like the service manager a lot or i would have pitched a fit. He's always been fair w me. I will not take my auto's back there, lesson learned. . And thanks guys for dealing w me venting. i just can't stand for simple things that could have a huge affect to go overlooked.
