A/C Noise
Old Aug 29, 2008 | 09:34 AM
savage250's Avatar
A/C Noise
Hey, I have a new 08 F150 FX4 SuperCrew. Whenever the A/C is on, I hear a hissing or purging noise every twenty seconds or so on the passenger side of the cab. It isn't very loud, if I have the radio on and am driving I cannot hear it, but the passenger hears it. Anyone else have this noise?
If I turn off the A/C, it goes away. Recirc doesn't seem to affect it.
Old Aug 29, 2008 | 03:38 PM
Josiah's Avatar
When I turn off my truck I have the exact same issue, but it's constant for about 20 seconds and then it stops purging. Sounds like the A/C, a little water leaks out onto the floor and then it's done. Anyone?
Old Aug 29, 2008 | 03:46 PM
If what you're describing is what I think it is mine has done that since new.
Mine does that too, but no leaking on the floor.
Old Aug 30, 2008 | 07:08 AM
svt2205's Avatar
Yup, I've got that noise too. Mines done it since day one and now 48K miles later still does. I wouldn't worry about it.
Old Aug 30, 2008 | 09:20 AM
midnight08's Avatar
i took mine in when i got my truck 08 FX2 and the thing would do what you are describing after shutdown for a good 30 minutes. i took it into the dealership because i thought that it wasnt normal for it to be doing it that long. they did something to it and now its fixed. i think they said that they relocated the drain tube so that it doesnt leak out onto the exhaust.
Old Aug 30, 2008 | 10:35 AM
they probably did the TSB about the PCV elbow on the drain tube exit to prevent drain back into the cab, and angled it so it would drip a little bit to the side from where it was.
