07 rear window leak
As the rains came down like a monsoon today I noticed water leaking in my truck from the back window! I took it by my local Ford dealer and have an appointment to have it repaired tomorrow evening.My service advisor said it is a common problem due to a bad 3rd brake light seal.Anyone else have this problem? Is there a TSB on it?
water leak
apparently this is an ongoing problem. my 04 was leaking bad. with suggestions that i found here, i unscrewed the third break light and found the seal flat as paper. i bought some foam trim and replaced it, the leak is less, but i think the third breaklight is cracked. my fault i guess.
just my 2 cents.
just my 2 cents.
My '06 leaked too. Strange thing was it leaked once, looked to be about 1/2 gallon of water. Made an app't for service and forgot about it, never leaked again. Maybe conditions were right for expansion, wind driven rain or whatever, but it was a 1x occurance. It did look like it originated from the area of the 3rd brake lamp.
Mine was leaking at the top on the corner, I just shot some clear silicone in there and it is fine now.
My old '06 did it. I bought a roll of weatherstrip from Homedepot. Pulled the 3rd brake light and removed the old seal as best I could. Put the new weatherstrip on and it fixed the problem. Dry as a bone after that.
If you go this route get the thinnest triple seal out there. I think it was 5/16" or something like that. I'd have to look at the product in the store to be sure though.
Took off the third brake light and added a bead of sealant around the whole assembly. The factory gasket was not lookin to good at all. I should now within a day or two as the rains continue if this does the trick.
