airbag light on help!!!!
Old Jul 30, 2008 | 03:14 PM
mguyott3's Avatar
i need soome help. when i start my truck my airbag light flashes one time then a pause and then 8 more times. it does this twice and then the airbag light stays on. Does anyone know what this is or how i can stop it. I already tried disconnecting the battery and unplugged the radiator sencor and pluged it back in to see if it had a bad connection.... what else could this be from?
Old Jul 30, 2008 | 03:25 PM
BlueFlareside's Avatar
Did you check the fuse? I have no idea.
Old Jul 30, 2008 | 03:37 PM
azmidget91's Avatar
like i said in the other one check the wire going to the light thats above the radio
Old Jul 30, 2008 | 03:40 PM
ELVATO's Avatar
Here's what I found searching around...
"Your code is for the passenger side air bag warning light circuit. Usually it is a blown bulb."
Hopefully someone with more knowledge can chime in.
Old Jul 30, 2008 | 03:41 PM
azmidget91's Avatar
yay im right but yeah could be a blown bulb or its unplugged, have you replaced the radio recently? or does it have an aftermarket radio in it?
Old Jul 30, 2008 | 03:48 PM
mguyott3's Avatar
thanks for the quick responce.. no i havent touched the radio i just bought the truck and the next day i noticed the light. but ill go out and check out that light. ill let you know.
Old Jul 30, 2008 | 04:25 PM
mguyott3's Avatar
ok.... so i took that passanger airbag light out and i think the lightbulb it blown. Its hard to tell though.... where do i get a new one of these? the dealer?
Old Jul 30, 2008 | 05:55 PM
Springer 1's Avatar
Had the same problem with my truck turn out to be a sensor in the front of the radiator next to the temp sensor.
The plug and the sensor was corroded because of the way ford mounts them with plug side up so it can fill water
Old Jul 30, 2008 | 06:53 PM
04F150supercrew's Avatar
i had a similar problem with an air bag light .... took it to ford and found out the pass front seat sensor was out of calibration. they did there thing and presto fine after that.
Old Jul 30, 2008 | 07:55 PM
mguyott3's Avatar
well since i didnt have a new passanger airbag off setup (piece above radio) and i cant stand having a light on in my cluster, I took a LED light i had around the house and just pushed the prongs of the LED into the plug connector for the bulb that lights up the passenger airbag off piece. And my airbag light shut off. I drove around for a little while and still no airbag light. THANKS AZMIDGET91!!!!
Old Jul 30, 2008 | 10:47 PM
azmidget91's Avatar
your welcome
