Creaking Sound in Front When Suspesnion Flexes A Little Over Bumps
My truck does the same thing too. I already took it to the local ford dealer & they found nothing wrong with the suspension. Sounds like a metallic nosie coming from the left front. If you find out or if I do before you please let me know as because this noise doesn't sound healthy
check your front sway bar. if the sway bar is slightly loose, it will allow the rubber peice to move around and cause some noise
Ok I think it's about time to lock these forums down. Every time someone post a problem it seems like I get the problem a few days later. I got the squeak now as well. grrrrrr. Going to wash the truck tomorrow so maybe that "rock" will spray out.
My ball joints are like 5 months old so it maybe the uppers but I doubt kinda that. I'm thinking sway bar as well. Too hot outside right now to just go out and gander. I'll crawl under there later this evening and have the wife use her fat butt for some good.
