Overheating w/ A/C on
Old Jun 5, 2008 | 07:01 PM
bjp207's Avatar
I have a 2004 4.6 scab 4x4 and its been about 75 degrees the past 2 days. With my A/C on the temp gauge has been getting up to the red when I'm towing 4000 Lbs and the A/C gets warm.
The radiator was flushed at 30K, and now I'm at 60K. Im taking it in to get a flush tomorow and to get the A/C system checked....is there anything else that I should have looked at that would cause the truck to run so hot?
I have a k&n filter and a magnaflow exhaust. Maybe if its running lean it would run hot? I am up for any suggestions besides not towing with my 4.6 haha.
Old Jun 5, 2008 | 08:44 PM
LariatRocks's Avatar
Fan relay is what I'd look for based on your mileage. Hard to say being online though...I'd use a Snap-On Modis and fire your fans, and then test your temp sensor.
Old Jun 5, 2008 | 09:12 PM
bjp207's Avatar
Alright...ill have them look at that too
Old Jun 5, 2008 | 10:11 PM
scott1981's Avatar
Fan clutch needs to be checked, yours was before they went to a electric clutch so yours is purely mechanical. Sounds like you have stayed ontop of your radiator cleanings but another wouldnt hurt
Old Jun 6, 2008 | 08:56 AM
05supercrew's Avatar
Thermostate might not be working properly.
Old Jun 6, 2008 | 06:15 PM
bjp207's Avatar
Well they checked thermostat, temp sensor, flushed the radiator, checked the fan clutch, and everything was sound. The coolant was still good but i had it replaced anyways.
It turns out that they flushed the tranny and the fluid was all burnt smelling and not so red anymore...It was also changed at 30k, so I have a feeling the tranny is not long for the world or at least the converter. I guess that the tranny getting so hot caused the engine to overheat. Tomorrow im going to order a trans temp gauge and I think im going to get an xcal with some troyer tunes here pretty soon so I dont have to worry about another one going this fast.
Thanks for the input though guys, greatly appreciated
