Wont go into 4wd low??
To get IN and OUT of 4lo, have to be completely stopped, foot on the brake, gear selector in Neutral, then go from 4high to 4low. Should go in/out if you follow this procedure. If not, you have a problem. Most likely the 4x4 shift motor on the transfer case.
