Tapping Into Constant 12 Volt
Old May 6, 2008 | 02:57 PM
eplstx's Avatar
Im curious about a few things. One i want to know if i tap into my cigarette lighter will my cigarette lighter still work? Also how would i go about tapping into a wire? And what color is the ignition wiring to tap into? is that very dangerous? also if i tap into the ignition wire what will give it juice? having it in the on position or when its started? Im sorry for so many questions. Thanks for reading.
Old May 6, 2008 | 03:38 PM
blackjack8900's Avatar
yes you can but I would not recommend it.
striping back the insulation about 3/4in wrapping the wire your adding around it and soldering it would be best.
Depends on what year your truck is....06-08 would be dk.blue/lt.green....here is a good site to check for what you have http://www.the12volt.com/installbay/vehicles.html
Not dangerous if you know what you are doing....it will be hot when the key is in the ON or RUN position.
What are you trying to add?
If if is anything thats pulls some juice you are going to want to run a new line right from the battery and fuse it, otherwise you will be overloading the ignition wire and blowing your ignition fuse.
Old May 6, 2008 | 03:39 PM
Monkey-1's Avatar
Here are the wires/colors in the steering column and what they do:
Battery--LIGHT GREEN/VIOLET--hot all the time
Ignition--BLUE/GREEN--hot only when key is on
Tapping into your cigarette lighter will still allow it to work, but dont pull too much current through it-its not designed for it. As for tapping into the wire, you can strip the wire, use a connector or a T-tap.
