need rancho lift kit help ASAP
Old Apr 27, 2008 | 06:49 PM
ATOM's Avatar
well i got it to the part where i need to drop the diff, how the sam hell do you get that upper front diff bolt out?
also how much do i gotta compress the coil when switching them over?
do i have to trim both sides of the crossmember or just the passenger side?
everything was going OK til the passenger upper ball joint bolt was stripped thanks ford its not going too bad though, at least the weathers nice. help me out guys
Old Apr 27, 2008 | 09:16 PM
VTHokieF150's Avatar
I answered your post in the suspension forum, except for the crossmember question. Its the DRIVER'S side you are going to cut... not the passenger side.
Old Apr 27, 2008 | 10:00 PM
mengela's Avatar
you got some friends man that can help? seems like you bit off a bit more than you can chew
1(upper diff bolt) is the steering system in the way? remove your clockspring per factory manual, turn your steering wheel remember to count turns and direction..
2(compress coil) im assuming that you are putting in new rancho struts, you need a strut compressor (macpherson strut and not coil compressor), although i would forget this and just take them in to pepboys, dealership, or any shop where they have a cage... just remember to index ALL the way down and on the coil and on the bottom a arm connection.
3.(srtipped ball joint)bet you didnt hold the smaller nut and just started cranking on the big nut
btw my first real mechanical experience was with that exact same kit, so ive been there
Old Apr 27, 2008 | 10:25 PM
ATOM's Avatar
1. i dont wanna remove the rack and pinion, the install doesnt says nothing about it, so i assuming its just a bitch to do with a wrench.
2. i borrowed them from my buddy, he just replaced his struts on his wifes car with em. i think im just gonna take em in.
3. no i held them nut on the bottom and it just stopped, dead. wont turn again, i tried everything, oh well at least its new i guess.
this aint the 1st lift kit i put on, just used to working on silverados.
Old Apr 28, 2008 | 04:44 PM
ATOM's Avatar
anyone ever have trouble with the subframe not lining up at all 4 corners?
Old Apr 28, 2008 | 04:51 PM
extremeethan's Avatar
yes lift kits are stupid I dont feel anyone makes a quality kit, mine didnt line up had to drill a little and now I cant get mine to align correctly
